Old 12-07-2012, 09:24 PM   #1
DriFD3S
DriFD3S's Avatar
Wicked!
JDM True Story.
JDM FTW.
Old 12-15-2012, 08:27 PM   #2
MotoTek
Always Under Construction
MotoTek's Avatar
UIM and LIM cleaned up.
Super*Now full pillowball suspension bearings replaced every bushing.
Zinc plated all suspension and engine hardward.
BLACKADDE™ | ADGT RX7 |
Old 12-31-2012, 03:39 PM   #3
diabolical1
I have radioactive semen
sucks about the engine not being what you thought it was. however, you sound like you'll be alright. would like to hear when it fires.
Old 01-11-2013, 11:32 AM   #4
gmonsen
The Ancient One
gmonsen's Avatar
gmonsen is on a distinguished road
Really nice, Mike.
Gordon
1993 Rx7 R1 20b NA
1994 Rx7 20b supercharged project
1991 BMW 850 6 speed
1991 BMW E30 M3 Evo II
gmonsen is offline   Reply With Quote
Old 01-11-2013, 01:30 PM   #5
Pettersen
Old 01-23-2013, 01:56 AM   #6
hybrid G
hybrid G is on a distinguished road
Did u zinc plate the Uim & lim as well?
hybrid G is offline   Reply With Quote
Old 01-31-2013, 07:42 PM   #7
MotoTek
MotoTek's Avatar
Close up of fixed collapsed coolant jacket repair and nitrating by Chips Motorsport.
Old 01-31-2013, 07:43 PM   #8
MotoTek
MotoTek's Avatar
Reaming of oil feed passages on the irons to the stationary gear bearings for increased oil flow; done by Chips Motorsports!
-8 with o-ring groove for a leak proof setup, not pipe threaded like other builders out there.
Because I'm also running a Mazdaspeed dry-sump system Chip will be doing some trick stuff that I'll post later, so stay tuned for some rotary related porn that you've never seen done to a rotary before!
Old 02-01-2013, 11:18 AM   #9
RX SE7EN
Why didn't you just weld a -8 AN bung on? Could have done away with threaded fittings all together.
Old 03-28-2013, 07:46 AM   #10
To_Slow
When was the last time you welded a fitting on cast side irons?..
My link
Old 03-30-2013, 08:01 PM   #11
Rotary Evolution
rotaryevolution.net
Rotary Evolution's Avatar
and when the weld breaks or the fitting breaks/strips you will know why it's easier to use a softer material for a threaded fitting.
ALL of those coolant walls failed? what did they store the engine with? muriatic acid?
Old 02-01-2013, 07:21 PM   #12
MotoTek
MotoTek's Avatar
Welds are ugly. IMO, this looks much cleaner even over TIG.
Old 03-18-2013, 07:57 AM   #13
Daedalus704
Daedalus704 is on a distinguished road
Any updates? So far the build looks amazing.
Daedalus704 is offline   Reply With Quote
Old 03-29-2013, 06:11 PM   #14
MotoTek
MotoTek's Avatar
Yes sir. Lets see where I left off, hmm...
Brand new 3 x S5 rotor housings and 3 x S4 Low Comp Rotors. The rotors will be lightened next, so stay tuned for pics of that.
Mock Up:
Machined the spark plug dimples off.
Some Coating:
Old 03-31-2013, 10:37 AM   #15
theorie
VRR PSSH
theorie's Avatar
theorie is on a distinguished road
So much inspiration coming from builds like this.
1993 SSM, 20B (D449), SINGLE-TURBO, DIY-BUILD IN THE WORKS... |Build Thread|
1993 BB, 13B, SINGLE-TURBO, DAILY DRIVER |Build Thread|
MY FACEBOOK PROFILE // BLACK LABEL ENGINEERING // ADVANCED RACE TECH // IR PERFORMANCE // THE BOOST LAB //
[url=rotaryaddicts.com]
theorie is offline   Reply With Quote
