#31 |
cxxxx|::::::::::::>
Rep Power: 17 ![]() |
#32 | ||
Rep Power: 10 ![]() |
Manifold Absolute Pressure Talk to Glennypoo about it... as I'm assuming he's the one that talked you into the FPSI Quote:
#33 | |
cxxxx|::::::::::::>
As for EMAP i honestly don't know what that would do for me. Enlighten me o mighty one. As long as i can get a 0-5v pickup i'm sure i could wire it into the haltech |
#34 |
I have radioactive semen
Rep Power: 18 ![]() |
#35 | |
![]() EMAP is nice for tuning for a few reasons.... specifically for you and I, it allows us to see a better place to run the transition. There comes a point when the EMAP gets so high the turbo's are basically a cork in the exhaust killing power. Using the EMAP to set the transition allows for tuning a smoother one. EMAP is also nice for tuning timing and you can use it to trim fuel while cruising.... but that's fancy Motec shit My EMAP sensor is the same as yours and my MAP sensor, just plumbed differently
#36 | |
cxxxx|::::::::::::>
I'm not sequential so i don't have a transition. But i see what your saying. So you run a basic 3bar GM MAP but run what a braided line from your DP into it? |
#37 |
cxxxx|::::::::::::>
#38 | |
Running EMAP in the DP could be useful info, but it wouldn't help with the tuning aspect of it, the line needs to be pre-turbo. I've got an SS 1/8" to -3 adapter threaded into the manifold. From there I've got 2' of SS brake line. At the end of that is a female -3. Then 8" of -3 braided with a male crimped on one end, and a female on the other. The MAP sensor is mounted in a billet mount threaded for 1/8" npt, so you just thread your adapter in there and the braided line screws on. The nipple on the actual sensor presses into an o-ring in the mount, trick little piecem eliminates all the fluctuations and shit you get from vaccuum tubing and the chances of the line getting pierced or blowing off are basically nill.
#39 | |
WNC Tour Guide
and of course, if you happen to be partial throttle... because, i dont know, you're playing in the mountains, you hit the tranisition point of the turbos and you don't have enough exhaust flow so you go from 7-8 lbs on one turbo to 0 LBS! on both turbos..and the car falls on its face... and let's not even talk about what happens when your in the middle of a curve and the 2nd turbo decides it's time to spool!!! previous owner's hubby got a little scared when i did that... twice...
#40 | |
cxxxx|::::::::::::>
I don't know if i'm sophisticated enough to pull something like that off. Perhaps something i'll look into when i get to single turboing the car |
#41 | |
I dunno what you're talking about... I never once had those problems playing in the mountains. If you're a good little boy I'll let you play too ![]() Piece of cake man, when it's time, lemme know.... very easy to do
#42 |
WNC Tour Guide
guess you were going too slow and are too low in your RPMs to have it be an issue =]
#43 | |
cxxxx|::::::::::::>
![]() OH SNAP! |
#44 | |
Do an M84... its only a $2500 ecu
![]() Quote:
#45 |
WNC Tour Guide
i was on bald tires... and doing the speed limit because i dont like giving $$ to TN...
| Bookmarks |
