Old 12-31-2010, 10:15 PM   #1
rx2fan
rx2fan's Avatar
rx2fan is on a distinguished road
Sorry to hear about your recent troubles. on a positive note, the bumper you made for the fron is great, it really transforms the look of the car compared to the original big bumpers.
rx2fan is offline   Reply With Quote
Old 01-01-2011, 03:39 PM   #2
Buggy
I've been Wankeled!
Buggy's Avatar
Thanks, I was fairly impressed with the bumper as well. Considering that was my first real custom metal work project I've ever done, I think it turned out pretty good. The coolant leak really isn't an issue. I think the upper rad hose clamp may be loose from sitting in the cold weather. I'll make sure the Rx-4 makes it to DGRR this year. Can't keep a true rotorhead down!
Old 01-03-2011, 01:20 AM   #3
diabolical1
I have radioactive semen
this is a pretty sweet project you've got. with any luck, i'll see it in person at Deal's Gap this year as i hope to attend as well.
Old 01-13-2011, 10:49 PM   #4
Buggy
I've been Wankeled!
Buggy's Avatar
Well I pulled the weber off of the beast tonight. Going to be taking it to a local weber guru to have it completely overhauled. Hopefully that will solve my fuel leaks from the throttle shaft and so on. Also got a line on a set of 15" Riken mesh wheels in 4x114.3 bolt pattern that I'm going to pick up on the weekend. Let the GSL-SE parts swap begin!
Old 02-12-2011, 04:11 PM   #5
Buggy
I've been Wankeled!
Buggy's Avatar
Time for a LONG overdue update. I've been slowly picking away at this project getting it ready for deals gap. I bought an aluminum flywheel and I also got a hold of that set of Riken mesh wheels. The wheels were not in the greatest shape and had gold centers, but the price was right. I've been busy sandblasting, sanding, and polishing the rims. Here's a pic of one of the better rims before...
After sanding, then wet sanding with 400, 800, and 1000 grit, and then polishing this is what the lips look like.....
I've got 3 out of the 4 rims polished and 1 rims is completely done all but for laying down a few coats of clear. More pics to come....
Old 02-14-2011, 06:28 PM   #6
Buggy
I've been Wankeled!
Buggy's Avatar
Here's the first rim all done.
Old 03-05-2011, 08:42 AM   #7
Buggy
I've been Wankeled!
Buggy's Avatar
The weather has finally warmed up here and I've started to work on the old girl again. Last night I worked under the hood and got the engine ready to come back out. After a season of driving I'm not real impressed how the engine looks so I'm going to freshen the paint up a bit. After today hopefully the whole drive train will be out of the car along with the front suspension.
Old 04-16-2011, 12:34 PM   #8
Buggy
I've been Wankeled!
Buggy's Avatar
Well the weather has been terrible here and it really cut into my free time to work on the car. I didn't get the suspension swap done and my transmission swap went south fast. After having the engine running for about 10 minutes the clutch release bearing seized solid. There was an issue with the length of the push rod needed for the slave cylinder between the stock 4 speed and the SA 5 speed. Also, when I drained the fluid from the 5 speed to remove it a big chunk of metal was stuck to the magnet. I believe it's a piece of a synchro. So as of now the car is sitting with no transmission in it. I may end up swapping the 4 speed back in and I'll suffer on the drive to DGRR.....
Old 05-28-2011, 01:46 PM   #9
Buggy
I've been Wankeled!
Buggy's Avatar
Time for an update me thinks..... Those of you that attended DGRR know that the car did make the trip and in fact made the trip quite well! No problems of any kind at all other than a thirsty appetite and possible permanent damage to my hearing. I was actually surprised at how well the car handled on the dragon. Can't wait until I get the suspension, wheels, and brakes swapped. All the parts are waiting, just have to find the time to do it. I did however find some time the other day to swap my 5 inch velocity stacks and larger fuel jets on my weber. WOW did that make a difference! Traction is now a definite issue in first and second gear. MUST SWAP LSD REAR AXLE! There will be more pics and progress of this car hopefully soon. I want to get a lot done on the car yet this summer. Here are some pics from the DGRR trip.
Also forgot, I'm planning on taking this car back to the dyno within the next few weeks to see what kind of numbers it's putting down now. Should be interesting....
DGRR2011.jpg226969_10150193906383297_512128296_6932857_8276263_n.jpg225513_10150193911413297_512128296_6932945_6274286_n.jpg227401_10150193911453297_512128296_6932946_7178331_n.jpg227982_10150193911498297_512128296_6932948_1561800_n.jpg
Old 05-28-2011, 09:23 PM   #10
Ian
REIAN
Ian is on a distinguished road
Subscribed! YA I was surprised how well it handled when we went down the the DGRR and thanks for letting me drive it! You would think I was a kid in the candy store with the grin I had the entire time I was driving...
1989 Turbo II. Track Car
1988 10thAE. Garage Queen 400+rwhp
Ian is offline   Reply With Quote
Old 08-13-2011, 06:18 AM   #11
Buggy
I've been Wankeled!
Buggy's Avatar
Well I've been really busy all summer and this car has just been kind of neglected. I drove it last night and I think one of the flex lines collapsed on me. I turned a corner and it started to brake pull like crazy and I could smell hot brakes. I guess it's time to tear it down and do the brake/suspension/axle swap. I have all the parts I just never had time to do it. While I'm at it the flex lines will get changed, (probably with stainless ones) and I'm going to send the master cylinder away to be rebuilt.
Old 01-18-2012, 08:35 PM   #12
Buggy
I've been Wankeled!
Buggy's Avatar
Well this car is back under the knife. I have it in my garage on jack stands. The entire front suspension has been removed so far along with the brake master cylinder and booster. Turned out the left front caliper actually locked up. Anyway all of that will be in the past. All new stainless flex hoses along with a set of camber plates have been ordered from ReSpeed and I plan on swapping in either an FB master and booster, or an FC setup if it will fit. After the front has all been done and I figure out my suspension drop, I'll start tackling the rear axle and suspension.
Old 02-26-2012, 08:33 AM   #13
Buggy
I've been Wankeled!
Buggy's Avatar
I made the trip to see Sam at ReSpeed yesterday and picked up all of the parts for the front suspension. Hopefully today with some luck I will get the front suspension and brakes together. I also took apart all of the exterior gauges and cleaned/polished them. I've tweaked the carburetor a little more and I upgraded my screens on the velocity stacks. I've also finally bought MSD coils and I made a proper bracket to hold all 3 coils together. No more zip ties! I'll try and take some pictures today to show you guys the mess in my garage.
Old 02-26-2012, 11:15 AM   #14
Ian
REIAN
Awesome Buggy! Can't wait to see the new upgrades on your cars. May make a trip up to ClassicAuto soon to check my car out and pick up a part or two..
Old 03-06-2012, 09:02 PM   #15
Buggy
I've been Wankeled!
Buggy's Avatar
I've been working away at this project and I've hit a few snags along the way. For those of you who think the GSL-SE front suspension is a "bolt in" swap think again. I had to drill out the holes in the bottom of the struts where the ball joint bolts up. The GSL-SE uses M12x1.5 bolts while the Rx-4 uses M14x1.5 bolts. Also finding a M14x1.5 tap is not the easiest thing to do. Luckily a friend's boss had one that I could borrow. I also ran into issues with the FB brake booster and master cylinder swap. The studs on the Rx-4 brake booster are much longer than the FB. To use the FB brake booster you have to remove the stock studs and somehow install longer ones. I decided to just reuse the stock Rx-4 booster. The next issue I ran into was with the brake master reservoir. The stock Rx-4 reservoir is remote mounted on the strut tower while the FB has it mounted directly on the master cylinder. This interfered with my DLIDFIS ignitors that I had mounted on the strut tower. After some thought and some parts swapping I got the stock Rx-4 reservoir to fit on the FB brake booster. Just had to remove the rubber seals from the Rx-4 master cylinder and swap them with the reservoir seals on the FB master cylinder. Anyway, after all that I finally managed to get a rotor on and I mounted one of my Riken wheels just to see how it was going to look and get an idea of the new ride height in the front. First thoughts, it's going to be low and mean!
