Old 06-12-2010, 12:05 AM   #1
Mazdabater
FC3S
Mazdabaters peice of crap FC.
I was going to go through and try and find some old pictures of the car when I got it, and some of the progress shots but it's too much effort and I got some more stuff planned for the car in the near future. So I figure Ill throw up a list of mods and my plans, then throw some pics later as my build goes on.
I brought the car fairly close to stock back in september 06. Currently its mod list is
Full bare metal respray in a custom red with yellow pearl
Rmagic body kit
17 X 8" front rims and 17 X 9 Rear. Unsure on the brand however they are very light so I don't think they are cheap crap.
Extend ported, dowelled with 2mm seals (possibly loosing compression under boost. Going to be bridgeported with RA super seals next month)
Steam pipe manifold
Pro boost 55mm wastegate
Pro Boost to4z turbo (This pro boost junk is getting replaced as soon as I can afford it, or when it fails whatever happens first. Looking at going to a garret gt42r)
Turbo beanie
3" stainless exhaust with Rotaflo muffler
PWR 55mm core radiator
Spal curved blade 3000+ cfm thermo fan (wired to ecu)
Microtech LT10s with hand controller
Walrbo 255LPH fuel pump
Billet fuel rails
Aeromotive FPR with braided lines
STD primarys and Bosch Indy Blue secondarys (1600cc)
SDR 3" throttle body snout
3" Stainless IC piping
600 X 300 X 76mm Chinese bar and plate intercooler
Tein coilovers with EDFC (electronic suspension controller)
Front and rear strut braces
Front sway bar
Braided brake lines
Diff cradle has been reinforced to stop it from throwing mounts
Coushined ceramic button clutch
Blitz auto turbo timer
Sparco race pedals
RX8 leather shift knob
Momo commando wheel
Aerospeed quick release boss kit
Recaro reclineable seats
Storage bins (my cars a jspec so I struggled to find these)
Optima yellow top battery relocated to passenger bin
Carbon dash insert
Carbon radiator cooling panel
Knightsports boost gauge
That's pretty much what I can think of off the top of my head, there could be more If i find it later I will list. Over the next couple of months it's getting
Rebuild - Will most likely get bridgeported
New ECU loom installed, the original owner had it spliced into the factory loom, looks hideous.
Carbon fan shroud + the panel that goes in front of the radiator. I had made one, but after installing the new intercooler I had to ditch the stock overflow bottle, So I'm gonna make a new one without the hole in it.
New underbody tray (going to add some extra ducting to this to get the air where it needs to go)
PWR oil cooler
Bigger alternator
Working out why the hell my fuel comes back out the fuel cap.
The car is currently making around 310rwhp. Far too low for this setup have tested everything trying to find the problem, have settled with the car loosing compression under boost. Which is why it's getting pulled next month. Aiming for around 450whp.
I'm currently re installing the dash in the car, as I pulled it out to fix up the aircon ducting (stupid foam seals) and re route some wires. Ended up finding a few birdsnests of wires back there that had to be removed.
I found a couple of pics from it after the repsray. Doesn't look quite as nice now as carparks have taken their toll on my doors, and a stupid little girl scratched the back of it riding her scooter too close to my car in the units I used to live in. The car also doesn't have the wing on it or the door handle painted in these pics. I'll take some more pics of it later after I finish putting the dash back in and give it a bath, it's been sitting in the garage for a month or 2 so it's pretty filthy
