Old 12-10-2014, 09:12 AM   #406
project86
Can't.Make.Up.My.Mind.
project86's Avatar
I just made a very large list of parts that go under the car..... mmmmmmm........
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 12-11-2014, 02:14 PM   #407
project86
project86's Avatar
Is there a specific type of grease you guys use to pack bearings. Or do you just whatever is on the shelf at Aut-O'Reilyzone?
'90 GTUs
'10 Toyota Prius
Old 12-11-2014, 02:16 PM   #408
chibikougan
chibikougan's Avatar
http://www.amsoil.com/shop/by-product/grease/
Old 12-11-2014, 02:17 PM   #409
project86
project86's Avatar
Ransom... are you the only on ever on this forum anymore haha?
'90 GTUs
'10 Toyota Prius
Old 12-11-2014, 02:19 PM   #410
chibikougan
Yes I do live here.
Old 12-11-2014, 02:20 PM   #411
project86
project86's Avatar
Yes I do live here.
You're creepin me out dude.. creepin me ooooooooooooooot......
'90 GTUs
'10 Toyota Prius
Old 12-11-2014, 02:27 PM   #412
chibikougan
I am always creepin.
Old 12-11-2014, 02:28 PM   #413
project86
project86's Avatar
well at least you're creepin with help for me haha
'90 GTUs
'10 Toyota Prius
Old 12-11-2014, 03:25 PM   #414
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
You're asking for advice about bearing grease on a rotary forum? I don't think anybody's car has ever run long enough to worry about the bearings.
Old 12-11-2014, 07:09 PM   #415
Mobil1 synth...
Available almost anywhere - WalMart, O'Reilly's, etc.
If you're paranoid, Redline...
Old 12-11-2014, 09:33 PM   #416
Ahem.... How many front wheel bearing problems have I had? Fighting them to years because of those brakes.
I've narrowed down my next try to the amsoil, redline, and motul... Just need to remember which one of the three was the better and that's what I'll try... Along with some new and improved ducting
Old 12-12-2014, 11:39 AM   #417
Sorry to get this off-topic, but can I ask what kinda problems are you running into?
The Japan guys kill the front bearings in a year / season with the stock, aluminum hubs.
This is why there are all-steel hubs available, which extends their life to up to 3 years / seasons.
This is the hardcore racing FC's...
Old 12-12-2014, 11:49 AM   #418
GySgtFrank
GySgtFrank's Avatar
Pretty sure Mazda didn't design their spindles and bearings to be thrown into corners at 150mph. Grease isn't going to help very much. Ever heard of such a thing as an upgrade?
What are the fast race car guys running at the track? Besides I haven't seen you post anything for him stating what doesn't work and why.
Thank you.
Old 12-12-2014, 12:54 PM   #419
Bearings are overheating and the grease is failing which is leading to the bearings breaking apart and seizing... not fun when setting up for a turn @ 90mph.....
I only started running into this problem when I upgraded the brakes to a two piece rotor. My theory is not enough cooling and the heat is being transferred through the AL hat to the bearings and fucking shit up in a hurry.
Carbotech race pads aren't helping either....
Where might one find these steel hubs you speak of
I will cut you.
It's actually happening on the street as well... then again... we all know how I drive soooooo yeah.... It will also happen during a 20 minutes session @ LRP.... but hauling the car from 150+ to 60 every 63 seconds with a few other braking zones in between isn't helping. I would venture that if I put the stock brakes back on the problem would go away, but times would be slower for obvious reasons. The ITS guys don't have this problem and they're putting down similar times as I am...
Thank you.
I will cut you DEEP!
Cheapo grease doesn't work, can't handle the heat. The fast guys at the track in ITS are running stock brakes with upgraded pads, all they're allowed to do. The other classes have destroyed the front ends of the cars to get ducting to the brakes. This is what one of my winter projects is. Move the oil coolers back to just infront of the of the wheel wells and duct them from the front bumper. Fabricate a Y in the ducting to feed the oil coolers and the brakes.
Before I had some Naca ducts in the belly pan... my thought was that being a bit of a high pressure zone... or so I thought, it would feed the brakes... I'm not so sure it is.... so the front of the front bumper we all know is.... we'll see what happens next year... car is officially off the street as of Midnight tonight
Old 12-12-2014, 02:09 PM   #420
GySgtFrank
GySgtFrank's Avatar
Where might one find these steel hubs you speak of :
Ford
