Old 04-06-2015, 07:27 PM   #361
RICE RACING
Don Mega
RICE RACING's Avatar
Just got a new clutch for the bad boy
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 04-06-2015, 08:12 PM   #362
chibikougan
chibikougan's Avatar
OOoooh what kind and why no pics!
Old 04-06-2015, 08:17 PM   #363
RICE RACING
Don Mega
ATS 3 plate carbon, will take some pics when it shows up (getting sent today).
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 04-06-2015, 08:21 PM   #364
chibikougan
Oooh now I must have pics!
Old 04-07-2015, 02:38 AM   #365
Slides
Is that the new one with both gearbox input and flywheel/clutch cover/stack carbon plates?
A mate just pulled what was a single disk (but with the stack style cover/assembly/centre) with a loose splined carbon disk out of his silvia, thing rattled and and transmitted vibration through the whole driveline on coast (although 180 phase 4 cylinders are obviously bad for this). He is only running low power and went back to a single sprung organic kit based on a 370 clutch cover.
I know you have used several brands of multi-plates before, do you find the non sprung centres ok for street driving? I know you don't go there any more but there seem to be a lot of people that are very happy with a couple of the japanese kits with sprung twin disk carbons on FDs.
Old 04-07-2015, 03:20 AM   #366
RICE RACING
Don Mega
No I got this semi carbon one for $2150Au brand new, it was a steal.
The full carbon that ATS make is custom and takes 5 months to make, they are $7500Au. I have run full carbon in Tilton 3 plate and they are fine, In all I have had over a dozen different carbon clutches in the one you are talking about the D-Core in Exedy I have had 3 of those and all have been fine, lots of those people all went off my recommendation from years ago when I was on there.... nice clutch, but even new (no wear) with proper power they will slip so not really suitable for a powerful FD set up.
Here is a little review of it here > http://www.evoxforums.com/forums/showthread.php?t=15381
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 04-07-2015, 03:28 AM   #367
RICE RACING
Don Mega
The 'un sprung' center is ONLY ok if its a floating hub full spline design, if its the ghetto multi plate splines then these are for the want of a better word............... FUCKED!
They will vibrate and shown differential wear on each spline on the disks and under high power on a Mazda input shaft will twist the input spline making it near impossible to get the gearbox off! I know as I did it multiple times with Tilton Rally Clutches (in twin plate).
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 04-09-2015, 02:49 AM   #368
RICE RACING
Don Mega
My clutch turned up pretty happy with the deal $2149.99AU roughly $1700US or so.
Here you go faggots.
It's only the 1200bhp version, cause I wanted it to drive like stock feel
Whole conversion kit
Clutch components in order of assembly
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 04-09-2015, 03:02 AM   #369
chibikougan
MOTHER OF GOD!
Old 04-09-2015, 07:21 AM   #370
Slides
Interesting the way they have treated the tongues on the plates and run recessed radius for reduced stress concentration so it can't crack from wear at the edge of the tongues.
Are you going to run the pull to push with a fork or a concentric slave? I guess if you don't have clearance issues in a tunnel the external slave is easier to check on/bleed and less likely to contaminate the clutch if it fails.
Old 04-09-2015, 08:15 AM   #371
RICE RACING
Don Mega
Yeah it looks ok, just as a general comment its probably the worst made carbon clutch I have owned (just the way its made), but not fair on it I guess comparing to units that are 2 to 3 times the RRP of this one.
We will see, some people rave about it and how good it is, being the old style 1:1 lever ratio it will last a long time (though I am assuming ATS know how to make carbon material that lasts?) but most of these buy in that technology from Tilton anyway.
I am going to run it with the parts supplied, just simpler to adjust and check free play of the clutch pedal etc.
Shit was too cheap for me to resist.
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 04-09-2015, 08:22 AM   #372
RICE RACING
Don Mega
Some c-u-n-t-s may find it hard to believe but yes I have had a few of these things LOL
MOAR@!!! (I have had 3 of these D-Core units alone@!)
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 04-10-2015, 01:11 AM   #373
RICE RACING
Don Mega
someone say misfire?
NOT HERE!
LOL
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 04-10-2015, 01:16 AM   #374
chibikougan
Ship it! NAOW!
Old 04-10-2015, 02:51 AM   #375
RICE RACING
Don Mega
I engraved the clutch today with the direction of the floater plates and even the carbon disks and put on the serial number, so shit that they do not do this from factory and just give you a gay arse sticker! and tell you in Manual to 'remember' the position of the plates when pulling it apart for checks and maintenance LOL.
The hardened flywheel and floaters and even hard coat on alloy cover a c-u-n-t to do but I DON MEGAED up and gagfactory gizz3000'nd it to perfection
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
