#316 |
Rep Power: 18 ![]() |
NO! You're old!
#317 |
Rep Power: 10 ![]() |
MIDGET!!!!!!!l!!!!
#318 |
Get off my lawn!!!
Rep Power: 15 ![]() |
If you two kids don't stop fighting I'm gunna turn this fucking car around!!!....
![]() But seriously, if the gear is the same and the only difference from 7 to 8 is the bearings.... I'm just gunna get 8 bearings and reuse my 7 stat gears. Does this sound plausible?
'94 Touring - Cursed '96 NA Miata '14 Mazda3 Hatch '14 Aprilia RSV4 R |
#319 |
Rotary Masochist
There is supposed to be a slight difference in the gear that makes the 8 more suitable for high revs, but they're interchangeable. The whole 8 gear/bearing isn't a whole lot more than the bearing itself. Even closer in price once you factor in having someone press the bearing for you and how many they'll possibly screw up.
The oil passages of the 8 gear do not properly line up with the 7 irons. A little work with a die grinder fixes that issue.
_______________________________________________ One stop Haltech, AEM, Syvecs shopping. Installation and tuning. http://www.lms-efi.com Free support. Drop us an email. chris@lms-efi.com 502-515-7482 Facebook @LMS-EFI |
#320 | ||
Get off my lawn!!!
Since I'm REALLY short on extra money right now (moving and had to hire a lawyer for work related stuff) I'm trying to cut out unnecessary expenses. Quote:
So I got the keg cracked open last night. Well... I got the rear stat gear and the studs out, along with the front stack and stat gear. The rear stat gear didn't want to slide off easily, so I gave it a couple gentle taps with a hammer and block of wood, it came right out. Both stat gears look good, the bearings are obviously needing replacement, but nothing is spun so far. I had to stop breaking the engine down last night because the wife was tired/hungry and we had already agreed to grab chinese food for dinner I pulled the rear iron this morning before work, the iron looks great, the rotor looks great. Photobucket is being a bitch right now so I'm having issues uploading pics... I'll dump the pics in when I'm able to get them from my phone to the interwebs..
#321 |
Get off my lawn!!!
Ok... Pic dump from last night.
Disassembly of the front stack: ![]() ![]() ![]() Off goes the front CW, looks good, slides around fine, everything seems good (aside from the stat gear bearings, they need fresh ones pressed) ![]() These guys look just fine ![]() ![]() Some surface marks, but I don't think it's outlandish... ![]() ![]() ![]() ![]() Like new... for the most part ![]() ![]() ![]() No whirling dervish's here!! ![]() ![]() ![]() ![]() ![]() Each part went into it's own sandwich bag, then came (gently) into here.. NOT planning on misplacing anything ![]() ![]() Left with this in the front. ![]() After the front was disassembled I pulled up the FSM and started loosening nuts to get the studs out. (And yes... it would seem there was a slight coolant leak ![]() ![]() By the time I got the studs out my wife was getting aggravated with me... She had gotten home about an hour earlier and wanted Chinese food for dinner (I needed to go out and get it ... A happy wife is a happy life, so I obey when it comes to fattening her up ). I went slightly out of order per FSM disassembly and cracked the rear stat gear off before removing the iron. A couple (relatively) gentle blows from the hammer/block of wood unseated the bearing and it came right off.![]() I don't know about you... but that bearing looks pretty damned good considering it ran without oil for a minute or so!! (I'm still gunna swap that out though, not taking any fucking chances!!) ![]() ![]() ![]() ![]() I did notice some odd marks on the stat bearing though... It looks like it either received pitting (without any sign of rust) or it did not fully smooth down a roughed finish on the metal.. I have no idea if that's normal or not.. ![]() ![]() ![]() Again though, the bearing looks remarkably un-mangled!! ![]() ![]() Here's the view I was left with last night when I left the engine for the evening.. ![]() This morning said "fuck that shit" and pulled the rear iron off while waiting for the car to warm up.. Rotor looks good... and it lifted on the e-shaft easily, so at least I know that THAT bearing isn't completely fucked and fused to the e-shaft.. ![]() You can tell that it looks like the e-shaft may have blued slightly though... BUT!! The Oil Control Rings look fine to my novice eyes (god PLEASE let them be good!!! Too many monies..) ![]() The Iron looks fine, though I didn't get a picture of it uploaded. Thank god for race clearanced rotors!!!
#322 |
Get off my lawn!!!
Welp.... I've got my motor fully stripped. Good news and bad news..
Good news is that both Stat Gears came out fine (new bearings would be good though), and the rear rotor is pristine. My irons look good and the housings seem great as well.. Bad news... the front rotor is pretty fucked up. The rotor bearing walked out about 1/2 an inch and is COMPLETELY thrashed. The rotor tips look like they def made some contact with the center iron (though oddly the center iron doesn't show any corresponding damage). I don't know if that rotor is salvageable or not.. I still need to remove/organize all its seals and clean it up some.
#323 |
Rotor is a nice new paperweight.
Send the iron to Chip for some cleanup and grinding/renitrating. The rotor clearly touched SOMETHING. just because you can't see damage, doesn't mean it's not there. On that note I would throw the front stat gear and front stack in the trash
#324 |
Get off my lawn!!!
I'm not trying to go all HC/BDC/JM Imports here... But why trash the front stack as well? They all look just as good as when they went in a few thousand miles ago.
#325 |
Because pieces of bearing material went through the entire engine. I wouldn't trust them, and I would definitely be replacing the oil pump.
You want to spin 8500+, make a gazillion hp, all the time and money going into the build, why skimp out on $100 worth of bearings and $150 pump? Sense, it makes none to me. I would also trash the front stat gear because it looks like it got too hot, I wouldn't trust it, I wouldn't use them, but that's me. Lost of people do shady shit and get away with it. I am not one of those people to try to skimp out when spending $10,000 on an engine.
#326 | |
Get off my lawn!!!
#327 | ||
I don't know nothing out that!
#328 | |
Professional Stick Poker
Rep Power: 16 ![]() |
I've heard prostitution is profitable. Get some'a them sexy UDT shorts and a cut-off T shirt, go hang out on street corners.
1988 N/A SE 2+2, dead stock and staying that way. ![]() 1979 SA22C stock? Not so much. http://rotarycarclub.com/rotary_foru...ad.php?t=15585 |
#329 |
Um that is his first job!
#330 | |
Stay off my corner!
| Bookmarks |
