Old 11-24-2009, 01:52 PM   #286
FC3S Murray
frustrated!
FC3S Murray's Avatar
ANYONE in regards to the endlinks???
Same pig, new soul
Old 11-24-2009, 02:07 PM   #287
The bolt on the control arm can only be one size becuase it's threaded into the arm. I would take which ever end fits more snug and put that on the control arm. Find a snug fitting nut & bolt for the top and have at it.
Honestly though, try driving around with no rear bar. Neither my lifted XJ nor my lowered 7 are running a rear bar and both feel great.
Old 11-24-2009, 06:54 PM   #288
/\ What kind of suspension mods have you done? Do you think that this would be beneficial on a stock suspension? I have heard that it's only worthwhile to do if you modified your suspension a lot. (ie: coilovers, RCA, bushings, etc)
Old 11-25-2009, 06:14 PM   #289
FC3S Murray
frustrated!
Hey quick question guys: When installing these Energy Suspension bushings, CAN you torque the lower control arm bolts before the FC is on the wheels. I know you dont torque the endlinks till wieght is on the suspension BUT I have found conflicting opinions on the matter.
Same pig, new soul
Old 11-26-2009, 02:49 PM   #290
FC3S Murray
frustrated!
What do you guys think?? Blitz 01 17x8 17x9. I will powder coat center graphite.
I think I am gonna do it. I may have a buyer for my SSR's
Same pig, new soul
Old 11-26-2009, 04:07 PM   #291
classicauto
crash auto?fix auto
classicauto's Avatar
those wheels are sex.
Pure furious animal sex.
Old 11-26-2009, 04:17 PM   #292
FC3S Murray
frustrated!
I know! They are sweet!!
Hey Classic you have any idea in regards to my bushing/ control arm torque question??
Same pig, new soul
Old 11-26-2009, 10:28 PM   #293
Which bushings in which arms Sean? If they are the front outer bolts on the rear control arms, snug them, but leave them loose, you'll want to be able to get to them when you set your rear toe.
Those were the bushing that I remember seeing last.
I'm digging the wheels.... ALOT
Old 11-26-2009, 10:34 PM   #294
FC3S Murray
frustrated!
They are the bushings on the front control arms. The two bolts that bolt the U bracket up the the front crossmember and then the long 17mm bolt that passes through the eye/bushing on the front bushing of the FRONT control arm. lol
Yes the wheels are so so nice. Cant wait to buy them.
Same pig, new soul
Old 11-26-2009, 11:18 PM   #295
Gotcha, torque it all down with the car in the air but make sure everything moves smooth.....stiff... but smooth.
Old 11-27-2009, 12:33 AM   #296
FC3S Murray
frustrated!
Thanks bro!
I hope thanksgiving was good. BTW I showed my cousin, who got me into the rotary scene your little turkey video. He laughed pretty hard, so did my mother and aunt. They cracked up when you yelled. "what the FUCK!" lol
Oh the good old times of family get togethers and large amounts of alcohol.
Same pig, new soul
Old 11-29-2009, 01:21 PM   #297
FC3S Murray
frustrated!
Anyone know if I can leave this line just hanging? The FSM says it is a check valve for fuel tank de-pressurization. It looks like it just routes from a nipple to the rear fender or pass rear storage bin. Nipple broke off in line when I was torquing my rear SB endlink bolt.
If it just a vent I should be ok BUT want to make sure.
Same pig, new soul
Old 11-29-2009, 02:12 PM   #298
just a nipple for the ventbro, maybe try cleaning it and then hit it with a little CA glue?
Are you still using your charcoal canister?
Old 11-29-2009, 02:43 PM   #299
as long as the tip valve thing can function (ie if you roll fuel doesnt come out of it) then i wouldnt be all too worried unless the smell of fuel bothers you.
Old 11-29-2009, 03:04 PM   #300
The tip that broke doesn't have the valve IIRC.... the check ball vavle do hickey is located in top of the tank and the 3 way connector is activated by engine vac.... IIRC... been a LONG time since I had to figure all that out.
I know what I did though, I took that valve in top of the tank and vented it to atmosphere through a sintered filter that I located on top over the fuel fill. I smell ZERO gas.
