Old 01-07-2010, 05:25 PM   #16
FujiRacing
FujiRacing's Avatar
FujiRacing is on a distinguished road
Our goal is to make it as easy as possible to bolt in a Rotary Engine at a reasonable price. Ricardo will be making the engine mount bracket and he also does custom work for Kilo Racing and he wants to make it good quality.
Jimmy
FujiRacing
www.fuji-racing.com
2010 13B Rotary Miata Semi-PP
2009 REDLINE TIME ATTACK Modified Class Winner Nashville & Englishtown NJ.(Miata Piston Motor n/a)
2008 REDLINE TIME ATTACK Overall Winner VIR Street Class (Miata Piston Motor n/a)
1990 FC3S Street Car
FujiRacing is offline   Reply With Quote
Old 01-08-2010, 11:17 PM   #17
Rx927
Rx927 is on a distinguished road
Yes, finally someone making Miata rotary Kits at a reasonable price. Are you focusing specifics(drop in and turn key) or just a base essentials (subframe,drive shaft,wiring, etc).
Very interested in a Base essentials style kit.
Rx927 is offline   Reply With Quote
Old 01-11-2010, 07:25 AM   #18
FujiRacing
FujiRacing's Avatar
First just the base essentials, like mounting the the engine and utilizing whatever we can with the least amount of custom parts then go from there. Keeping the price reasonable is our main goal.
Jimmy
FujiRacing
www.fuji-racing.com
Old 01-16-2010, 02:48 PM   #19
FujiRacing
FujiRacing's Avatar
Tommorrow I will be pulling the motor out of the FC and I will have Ricardo over (Kilo Racing Machinist) and Raul, and we will test fit the spare engine into the Miata to see the best way for mounts.
Jimmy
FujiRacing
www.fuji-racing.com
Old 01-18-2010, 06:44 AM   #20
FujiRacing
FujiRacing's Avatar
Got a pretty good idea now. We will be making a custon bracket so that you can bolt the engine in. Looks like no welding and will be bolted in. Subframe may have to be notched slightly but no firewall cutting.
Price range $500-$700
Jimmy
FujiRacing
www.fuji-racing.com
Old 01-25-2010, 06:58 AM   #21
FujiRacing
FujiRacing's Avatar
On Saturday we took the Miata tranny out, took all of 15 minutes. Gotta love RWD. This way we can test fit and make the custom bracket with the engine/tranny. We need to have the car ready for the Superlap Battle in November.
Jimmy
FujiRacing
www.fuji-racing.com
Old 01-25-2010, 12:51 PM   #22
just curious, how you ever used megasquirt? Might just be in my tuning in general, but im having trouble figuring out what the car wants with these ITBs.
Old 01-26-2010, 08:04 AM   #23
FujiRacing
FujiRacing's Avatar
I never have but if I do go the Megasquirt Route they will be tuning it for me initially since they are not that far from me. One of my customers from Canada drove down last year to Florida with the Megasquirt & ITB's and it worked fine.
Good news I just got. The REDLINE TIME ATTACK has a meeting with Sebring Raceway and if they can secure a event there we need to have the car ready.
Jimmy
FujiRacing
www.fuji-racing.com
Old 02-04-2010, 11:34 AM   #24
FujiRacing
FujiRacing's Avatar
We will be including a New Oil Pan in our swap kit.
Jimmy
FujiRacing
www.fuji-racing.com
Old 02-10-2010, 04:46 PM   #25
FujiRacing
FujiRacing's Avatar
Pulled the FC Motor apart and we will be able to use the 9.7:1 Rotors and we will be using the 4 port 12A or 4 port 13B side & center plates.. It's been done before and we have the machining capability. Looks like we will be using the Kaaz LSD, since that is the best one for the Miata in our opinion.
Jimmy
FujiRacing
www.fuji-racing.com
Old 02-22-2010, 07:28 AM   #26
FujiRacing
FujiRacing's Avatar
Originally Posted by MaczPayne View Post
EFI or Carb? Rotaries and Miatas are meant for eachother!
Just for giggles, here's my buddy's (Fris @ Lucky7Racing) Rotary Miata
It's has EFI now:
Good luck on your build!
Whose EFI (Blue Trumpets) Throttle Bodies are those?
Jimmy
FujiRacing
www.fuji-racing.com
Old 02-22-2010, 09:43 AM   #27
Gregory Casimir
^^damn that is nice!
Old 02-22-2010, 09:57 AM   #28
Look like Tweakit's to me.
Old 02-23-2010, 05:22 PM   #29
FujiRacing
FujiRacing's Avatar
Thanks! That's what we are looking at now since we want to use twin fuel rails with 4 injectors.
Jimmy
FujiRacing
www.fuji-racing.com
Old 03-04-2010, 01:22 PM   #30
ziig
ziig's Avatar
ziig is on a distinguished road
those are from tweakit..in AUS....very affordable too
I just comleted my miata turbo rotary swap...went weber blowthorugh...did some initial dyno runs on 5 psi and made 250 whp....not too bad for a To4e on low boost..
just waiting for spring to get here so i run her out a bit....
will post some pics when i get some
ziig is offline   Reply With Quote
13b rotary miata
