Old 10-11-2009, 09:18 PM   #16
Jeff20B
Jeff20B's Avatar
Yeah my tranny was dying. It was a '79 5 speed that had far too many miles on it. 1st gear eventually stopped working and it would feel noticeably laggier each time I'd floor it. Like the bearings were fried and they'd heat up when running full power through them. I eventually located a ribcase tranny and it's been fine since. I suspect my mileage has improved to about 10 mpg.
Old 10-11-2009, 10:25 PM   #17
100 percent improvement! take that federal regulations!
Old 10-12-2009, 02:03 PM   #18
Jeff20B
Jeff20B's Avatar
lol
The above mileage was calculated while it still had the awful exhaust and a stock Hitachi carb jetted to run too rich all the time for the thermal reactor to get a rich enough mixture to burn completely and all that. Since then I've gone to a collected RB header and a single 2" free flow system with a Camden. The exhaust is far too small for high RPM use (gonna redo it in 2.5") but the Camden can be driven in such a way that it improves mileage over the stock carb.
So if I had to guess what its mileage will be after the free flowing exhaust is installed, and the new engine, with the Camden, I'd have to say probably in the neighborhood of 15 mpg. Remember it's a heavy vehicle with a somewhat low geared rear end.
I did recently swap over to a light steel flywheel though, which acts like less unsprung weight, for a minor improvement is gas mileage.
Old 10-12-2009, 09:48 PM   #19
12arotary
tumor-syphilis-itis-osis
12arotary's Avatar
^^^I think stock is rated at 15 city 21 highway
82 300d
82 Gsl
84 b2200 Diesel
88 gxl
Old 10-25-2009, 01:17 PM   #20
Jeff20B
Jeff20B's Avatar
Heh yeah it may be rated for that but I doubt it gets that much in real life. A Renesis would be a serious contender in the REPU actually. They're somewhat plentiful now and would only need a few mods to make it fit the REPU bay.
Old 12-17-2009, 11:35 PM   #21
Madaz
Madaz's Avatar
Madaz is on a distinguished road
Originally Posted by j_tso View Post
The only other very rare RE was the 13A sold only in the front wheel drive R130 Luce. It had taller rotors that were the same width as the 12A. I think the new 16X is very similar in size.
Yes your correct about the 13A sharing the same rotor diameter as the 16X however its width is the same as the 10A at 60mm.
Madaz is offline   Reply With Quote
Old 02-19-2010, 08:13 PM   #22
12arotary
12arotary's Avatar
Where did you find that pic?
82 300d
82 Gsl
84 b2200 Diesel
88 gxl
Old 02-20-2010, 03:23 AM   #23
Madaz
Madaz's Avatar
I took that pic
Old 02-20-2010, 11:57 AM   #24
12arotary
12arotary's Avatar
Originally Posted by Madaz View Post
I took that pic
whoa! you want to take a picture of the whole housing?
82 300d
82 Gsl
84 b2200 Diesel
88 gxl
Old 02-20-2010, 05:33 PM   #25
Madaz
Madaz's Avatar
Sure thing
Here are some pics, and a video to hear the sound.
http://www.youtube.com/watch?v=7TXBCQ4jFlE
Old 02-20-2010, 06:37 PM   #26
12arotary
12arotary's Avatar
video is marked private but those pictures are great! is that a running engine then? very badass!
82 300d
82 Gsl
84 b2200 Diesel
88 gxl
Old 02-20-2010, 07:21 PM   #27
Madaz
Madaz's Avatar
The 13A is to the 16X, the same as the 10A is to the 13B.
Old 03-08-2010, 12:10 AM   #28
12arotary
12arotary's Avatar
where exactly did you come across a 13a anyways, I search everywhere and the best I've ever found is a blown 10a and a lot of blown pre rx7 12a's and 13b's
82 300d
82 Gsl
84 b2200 Diesel
88 gxl
Old 04-14-2010, 05:42 AM   #29
Madaz
Madaz's Avatar
Back in 1991 I gifted the piston engine from my 1970 Mazda Luce Estate engine to well known local rotary engine builder Glenn Munro of Rotary Power Limited in Auckland New Zealand.
He "re-payed" the favour in 2008 by supplying me a 13A and trans at mates rates for my Luce RX87.
Less than a thousand 13As were produced compared to a couple of hundred thousand 10As so yes 13A engines are very very hard if not impossible to find.
The US only got the 10A in the R100 so 10A's are rare indeed in N.America
RX3 10A engines are still easy to find in Australia/NZ if you really want to get one. Cosmo and R100 10A's are getting harder now to find.
Have you searched Japan? 13A engines were exclusive to Japan only.
