Old 09-28-2009, 04:12 PM   #16
dudemaaan
dudemaaan's Avatar
No special tool is needed for the ear clamps, pretty much any kind of pliers will work just fine. Hell a rock and a screwdriver could probably be used in a pinch.
My writeup for 3rd gen Here (same for 2nd gen just different amount of lines required)
The tubing is part number MSC # 48701031 currently at This link $2.19 per ft
Ear clamp part number is MSC #: 48547962 $.41 ea Currently found here
Old 09-28-2009, 04:13 PM   #17
Originally Posted by parrotfever View Post
Great source to know - I've been following as I know I'll be doing the same rebuild. Can you rcheck the clamp & hose links. They come back as not found. Many thanks!
probably because I was using their in-house search function.
Tubing (filter by "Teflon" which covers all teflon materials, then filter by ID and wall thickness)
http://www1.mscdirect.com/Rubber-Tub...000000862.HTML
clamps (filter by 2-ear, then by necessary diameter)
http://www1.mscdirect.com/Ear-Type/H...000000800.HTML
Old 09-28-2009, 04:14 PM   #18
dudeman thanks for finding the correct tube and clamp sizes. I was too lazy
Old 09-28-2009, 04:54 PM   #19
dudemaaan
dudemaaan's Avatar
Yep no problem
Old 10-15-2009, 11:42 PM   #20
Originally Posted by FerociousP View Post
2nd gens have 4 lines.
clamps
http://www1.mscdirect.com/CGI/N2DRVS...00000110251736
clamp tool (should be able to find it locally cheaper)
http://www1.mscdirect.com/CGI/NNSRIT...03484&PMT4NO=0
hose (gauge your own ID and wall thickness)
http://www1.mscdirect.com/CGI/N2DRVS...00000110252129
holy shit you bought a "tool"??? Lol, I just used slip joint pliers, it's my fav tool to use, and it worked just fine.
Old 11-12-2009, 04:50 AM   #21
dawicka2
dawicka2's Avatar
dawicka2 is on a distinguished road
Wow, i didnt even know there was a "tool".
I went to the tractor store and bought weedwacker fuel line for like 1.50 or so, then used thick aircraft fastening wire and twisted it on to hold it.
That was 2 trouble free years ago.
john ny
dawicka2 is offline   Reply With Quote
