Old 09-20-2009, 10:42 PM   #16
Damn strait!
Chris, I say this with great sincerity, I love it, but I need dyno sheets
On a VERY serious note though, upon completion of reading this post you are to immediately go outside and drain ALL the coolant. Then flush repeatedly with fresh water. Water Wetter eats coolant seals alive. Someone that I know, repect and trust implicitly did a series of tests regarding coolant seals by placing them into various solutions. Water wetter was one of them and within hours of being imersed in the stuff, the coolant seals where falling apart. He conducted this test because one of his customers had a race car that needed an engine every year from coolant seals. He quickly found out that he was using strait water and water wetter, so he decided to test thier tolerance to the stuff, the seals have no tolerance. I hope you read this quick........ acutally I'm going to send you a PM as well.
-Brian
Old 09-20-2009, 10:45 PM   #17
wow crazy good to know. So much infact, im adding to the FAQ as you read this.
Old 09-21-2009, 03:15 PM   #18
RotorDad
Big Ugly
RotorDad's Avatar
The water wetter is for the aftercooler not in the motor, I had heard not to run it in the coolant sys. & drained it some time ago. As far as power goes I don't have any dyno sheets sorry, 10 years ago it was around 296 hp. Now that was when it was carbed, no aftercooler, on a different boost pulley set up, no nitrous & still had the clutch fan. With me being on partial unemployment I don't have the funds to get things finished or dynoed right now. I just got the new boost pulley which should be 14 psi, but now that I enlarged the main pulley to overdrive the charger it might be a little more. I will let you all know soon as I get the car back together, I'm having an electrical problem. Not really looking to make big numbers with this car around 350-370 pre nitrous would be nice. Gravity I know man I have been meaning to get under hood pics up, but I have been changing things around in there. for the past couple months I have only worked on the car maybe 3-4 hours. I go out to the garage then I get fustrated with my financial situation & don't want to mess with the car. So I just posted the shitty pics to at least get some up.
Boosted Big Body On 335's
PS3 ID: Rotordad
