Go Back   Rotary Car Club > Classifieds > 2nd Gen Classified > 2nd Gen RX-7 Parting Out
2nd Gen RX-7 Parting Out Parting Out Mazda RX-7 You must have over 4 parts to list your items here. No new parts allowed.
Old 07-19-2009, 09:37 PM   #16
PM's Returned.
Oh ya, I still have everything listed that's for sale.
Old 07-26-2009, 02:35 AM   #17
SlIcK wILlIe
SlIcK wILlIe is on a distinguished road
Pic of the s4 turbo mani to bandedgandr@hotmail.com
SlIcK wILlIe is offline   Reply With Quote
Old 08-26-2009, 06:49 PM   #18
Alright, all these things have to go! Make me some offers.
Old 08-28-2009, 08:15 AM   #19
pm's returned
Old 09-11-2009, 10:48 AM   #20
Make some offers! Seriously.
S4 Tails
***S4 Tubular Manifold***Sold
S4 NA ECU
CAS (N326)
S4 NA Air Pump
S4 NA ACV W/ Gasket
S4 NA Charcoal Canister
S4 NA Exhaust tips (look to be painted stainless steel)
S4 NA Brake Ducts
S4 NA Air Box
S4 NA Snorkle
S4 NA Rats Nest w/ Solenoids (except EGR)
Front Tow Hook
Brown/Red Door weather stripping
S4 Red Inner vent (can't tell if it's passenger or driver side.)
S4 Red lower driverside body piece (covers mounting locations of the center portion of the dash)
Red 4AWG (Might be 0AWG) Battery wire
S4 GXL Mirrors (Electric)
Stock Spark Plug wires
2 S4 Power Rack Ball joints
2 S4 Power Rack outer TieRods
New S4 side marker lights (amber)
Universal RPM switch
S4 NA Front cover oil seal (sits around hub)
S4 Cruise control computer (? FB01A)
S4 Rear view mirror triangle (Passanger side)
Little black box that connects to the back side of the logicon
2 S4 Amber front lenses (right side)
S4 Fuse Cover with identifying sticker
Big bag full of random nuts, bolts, lugs
S4 Clutch master cylinder
2 RX7 End-link kits from energy suspension (graphite empregnated-- 9.8134G)
S4 NA EGR valve
S4 NA Shifter Boot and E-Brake cover (plastic)
Random S4 TII connections (Stainless steel oil return line, solid feed lines, etc--from a stock turbo)
S4 NA Old but still good vac lines (if no one wants these I'll probably just trash them)
1 2.5" aluminum charge pipe standard length
1 2.5" 90* aluminum charge pipe standard length
4 Red Silicon couplers
8 stainless steel t-bolt clamps
1 S4 NA Oil Pan Gasket
1 S4 NA Upper Intake Gasket (connects the pnelum to the Intermediate intake runners)
1 S4 NA Upper Intake Gasket (connects the intermediate intake runners to the LIM)
1 S4 NA Lower Intake Gasket (connects the LIM to the engine)
1 S4 NA Exhaust gasket (connecting the thermal reactor to the catalytic converters)
2 S4 NA 6PI Gaskets
2 Hard Lines (Charcoal cansiter lines, big diameter, small diameter)
1 S4 NA Modified Secondary Fuel Rail (unknown condition--may need welding to be useable. -6AN fittings tapped and mounted on each side)
1 1/4 NPT male to -4AN Male (brass)
5 GLX/Turbo S4 Wheels ranging from excellent condition to fair condition
Old 09-15-2009, 01:41 AM   #21
3rd and final 7
3rd and final 7's Avatar
3rd and final 7 is on a distinguished road
great seller thank you
3rd and final 7 is offline   Reply With Quote
Old 09-15-2009, 01:59 AM   #22
need RX7
Clean S4 Nutswinger
need RX7's Avatar
How much for these to 48310? Details on the RPM switch? And what diameter are the clamps?
Old 09-18-2009, 12:35 PM   #23
Shipping to 48310 will be 16 bucks (flat rate)
Clamps are 2.5"
RPM switch is a new out of box unit from Summit using dip switches (not nodes/inserts).
Old 10-02-2009, 12:16 AM   #24
Drama
Drama's Avatar
Drama is on a distinguished road
How about the trim around the windshield, Looking for the side parts in a unbusted form, The color can be faded just need to be in good uncracked condition.
10th A.E. with 94 Twin Turbo FD Engine, With a precision turbo SC 60. Tokico Blues, B & G springs, Racing beat sway bars, Fender braces, F & R strut braces, Stainless brake hose`s, Toe eliminator busings, Carbon/Kelvar GT300 hood, Depo Gauges,Catz fogs,Sparco 383 steering wheel, 3rd gen shifter knob.
Falken Anzenis Rt 615`s
Front wheels 17X8+35 245/40
Rear wheels 17X9+44 with 5mm spacer 275/40
Drama is offline   Reply With Quote
Old 12-09-2009, 09:14 PM   #25
fc nut
member
how much for the rpm switch?45036
Old 12-30-2009, 09:19 PM   #26
Guys, if you want quotes for shipping you need to PM me! I'm horrible at checking this thread
Make offers on the parts you want!
But if by the end of Jan comes along I may just trash it all.
Old 12-31-2009, 02:53 AM   #27
Howru
Louvers!
Howru is on a distinguished road
Sent you a PM
88 GXL N/A -- Maybe I should've kept the exhaust diffusers...
Howru is offline   Reply With Quote
Old 12-31-2009, 10:30 AM   #28
PM returned.
Old 01-08-2010, 02:17 AM   #29
Howru
Louvers!
S4 NA EGR valve
2 S4 NA 6PI Gaskets
S4 NA ACV W/ Gasket
S4 NA ECU
Red Battery wire
Sold to me. Just got them in today!
Old 01-08-2010, 04:32 PM   #30
S4 NA EGR valve
2 S4 NA 6PI Gaskets
S4 NA ACV W/ Gasket
S4 NA ECU
Red Battery wire
Enjoy them. Summit should have the directions for the RPM switch up on their site if you look for it. I think it's standard wiring just grey and white are the on-off when triggered (don't know which one's which), and the yellow I believe is the signal. But double check to make sure.
body, engine, suspension
