Old 04-16-2009, 10:03 PM   #16
JShiz
ZOMG WTF BBQ!!!
JShiz's Avatar
Originally Posted by FirstRotaryExp View Post
Re-Speeds kit is spot on and a great upgrade for the FB, and for those guys that dont want to change wheels (4 lug to 5) simply substitute the FC 5lug hubs for the 4 lug, get a set of blank rotors, and have the 4 lug pattern drilled for them.
I'll do this then and leave my backs alone
Old 04-20-2009, 10:52 AM   #17
RX-7 Chris
RX-7 Chris's Avatar
where do you get blank rotors to drill for the 4 lug?
Old 04-20-2009, 11:31 AM   #18
bwaits
Talk - Action = Nothing
bwaits is on a distinguished road
They do not exist. You will need 5 lug rotors. A machine shop will need to locate on one of the existing holes and then add 3 more. You will end up with dual pattern.
-billy
bwaits is offline   Reply With Quote
Old 04-20-2009, 12:34 PM   #19
is there any way to upgrade the back of the car to 5 lug as well? Different bolt pattern wheels is kinda meh...
Old 04-20-2009, 01:18 PM   #20
staticpat
Rally Fanboy
staticpat's Avatar
staticpat is on a distinguished road
On the same token ... can you get a machine shop to re-drill a set of 4 lug rotors to 5 lug?
staticpat is offline   Reply With Quote
Old 04-20-2009, 01:49 PM   #21
yea, Billy sells Moser axles in the 5x114.3 pattern
Old 04-20-2009, 03:13 PM   #22
bwaits
Yes we have the axles as well as rear brake kits for 5 lug rear brakes.
No, it does not work going backwards do to the placement of one of the stock counter sunk holes.
-billy
Old 04-21-2009, 12:30 PM   #23
JShiz
ZOMG WTF BBQ!!!
JShiz's Avatar
Can I use a 4 lug FC front rotors and do the big brake upgrade?
Old 04-21-2009, 04:58 PM   #24
FirstRotaryExp
You can use the FC single piston calipers and rotors an it should fit just the same. But I dont think you can use the 4pot calipers with the 4lug rotors, dont quote me on that, but I 'doubt' anyone makes a beefy 4lug rotor for the 4pot caliper, I could be wrong though, but it wouldnt hurt to call a few parts stores to see what can happen, I managed to use a 5 lug rear hub o my fc, but continued to use the base model 4lug caliper and not so heavy duty rotor.
Old 04-22-2009, 05:26 PM   #25
bwaits
No in order to use the 4 piston caliper you will need to use the larger rotor.
Many use the 4 lug hubs with re-drilled 5 lug rotors to do this though.
You simply pick up the center of one of the 5 lug holes and drill 3 new ones.
-billy
Old 06-24-2009, 03:18 PM   #26
IH8DSM
IH8DSM's Avatar
so you said stock fc wheels wont fit without the 1" spacer, does anyone know what the stock fc offset is?
Old 06-24-2009, 03:26 PM   #27
Adler, just pick one from the pile you guys have and look on the back side. Should have the size and offset somewhere.
Dork.
Old 06-24-2009, 03:29 PM   #28
IH8DSM
IH8DSM's Avatar
Dork.
im lazy, and didn't even think of doin that haha
Old 06-24-2009, 05:49 PM   #29
bwaits
They are somewhere in the 40MM range.
Old 06-24-2009, 11:03 PM   #30
PercentSevenC
Custom User Title
PercentSevenC's Avatar
You just need the Moser axles and big brake kit for the rear. All from ReSpeed.
