Old 03-17-2009, 09:35 AM   #16
dfoster154
Boost Addict
dfoster154 is on a distinguished road
Originally Posted by sk8world View Post
I find these numbers close. I made 323 at 13-14psi (creep) on a old stock motor with basic bolt ons. And these numbers were on a dynodynamics unit but converted to dynojet numbers.
hmmm I just reread your post, based on the DynoDynamic to DynoJet conversion I would be looking at 320ish as well...
Maybe I do need to spend the $$ on AI and start running a water meth mix to get more.
dfoster154 is offline   Reply With Quote
Old 03-17-2009, 10:48 AM   #17
afterburn27
afterburn27 is on a distinguished road
I think those numbers are reasonable as well. With 10 psi on bolt-ons, stock ports, stock fuel, RP mapped ECU, & stock seq. turbos I dyno'd 300whp uncorrected on a humid 95 degree day with NO FAN, lol heatsoak. The corrected number was 321whp, but the SAE correction isn't really accurate for turbocharged engines. (Dynojet numbers)
I ran at 14 psi occasionally and that car pulled like a raped ape up top. AFR's were solid, although I'm sure I was close to maxing out the injectors.
I never took the car to the track, but on the street I was able to easily run down a few low 12 second cars.
'93 RX-7 (GT3574 track toy)
'74 Triumph TR6 (weekend cruiser)
afterburn27 is offline   Reply With Quote
Old 03-17-2009, 02:20 PM   #18
sk8world
600rwhp club member.
Thats the ticket... Go to the track and get a trap speed, that tells all..
I am trying to go back and find my stock twin dyno. It was 323 at around 13-14psi. Bottom line is stock twins are a blast to drive. I had mine going 7.8's in the 1/8th back 10yrs ago with just intake, exhaust, pettit IC and PFC computer.
6.? @ 11? drag pass
http://www.youtube.com/watch?v=9wfxT2RMr7c
Old 03-17-2009, 05:24 PM   #19
hades
i assume everyone with full exhaust also port their wastegates and installed boost controllers?
This is going to tear
Old 03-17-2009, 09:42 PM   #20
dfoster154
Boost Addict
My wastegate is stock, and I have boost controlled by the PFC through Injector Duty Cycle. In the cold temps boost will push 13.5 psi, but in 60degree + I typicall top out at 12.5psi
Old 03-18-2009, 11:57 AM   #21
albertomg
Pretty cool. Would you happen to have a better view of the dyno plot? I'd like to see the low end of it as well.
93 Vintage Red R1
Power: Street Ported Motor, 99 Twins, V-mount, DP>SMB cat/MP> RB cat back, PFC, 1300cc secondaries, Fuel Pump, ACT clutch, RB lwfw, etc
Steve Kan tuned - 310rwhp at 10PSI
Suspension: Tripoint custom valved Koni + Ground Control coilovers, Eibach sway bars, SuperPro bushings, Corner Balanced and accurately aligned
Brakes: RacingBrake 4 corner BBK
SSR Integrale 17"x9" +45, Dunlop Star Specs 255/40
Old 03-18-2009, 01:09 PM   #22
Signal 2
Viable Fossil
Signal 2's Avatar
Originally Posted by Doc-1 View Post
Okay had the old girl Dyno=ed last night
The car is stock except for the 3 inch exhaust but it has a high flow cat, air pump with a stock air box, has 99 spec twins running in stock configuration
Probably missed it, but I'm still confused. ^From this I assumed Doc was still on a stock ECU, but subsequent posts refer to his "tune" and the fact he has "99spec twins". So it is modified with a programable or reflashed ECU? And wouldn't 10 psi on 99 twins be the same as 10 psi on stock twins?
I'm not certain you'd get all that much of a challenge from the "other forum". I seem to remember some of the established guys there already mentioning serious gains to be made just with a DP, hi-flow cat and cat-back. Can't remember for sure, but the figure of 20 whp as being tossed around.
Jim
VR R1 FD
Old 03-18-2009, 01:22 PM   #23
dfoster154
Boost Addict
Here is my car's dyno sheet from last may.
Old 03-24-2009, 02:45 PM   #24
the spyder
the spyder is on a distinguished road
Interesting.
Im making 336whp on a 99 motor, twins, 93 PFC, full 3" exhaust, intakes, and stock intercooler. However I am maxing out my injectors, need to upgrade to a SMIC, and properly duct it. Looking for 360whp ish.
the spyder is offline   Reply With Quote
Old 04-08-2009, 03:34 PM   #25
Cp1
Cp1's Avatar
Originally Posted by Chadwick View Post
I would get 15 B.S. posts if I put this on the other forum; the reason for the good numbers are the 99 turbo's and a good tune. The abraded seals make them 10-15% more efficient at the same boost level. I can only guess that at some point some respected person on the other forum posted that the seals didn’t do anything and everyone jumped on the bandwagon, but I can tell you from experience that they do make a difference. I put down 315 rwhp at 10 psi, but my engine also has 9.7:1 compression rotors.
Dan
reduced clearances do indeed make a huge flow difference on turbos like rad fans. those 99 turbos flow a lot more air than stock because of those abraded seals. if anyone disagrees tell them to remove their radiator fan shroud and see how little air they move then!
Old 04-08-2009, 06:59 PM   #26
Signal 2
Viable Fossil
Signal 2's Avatar
They're more efficient.....yes. Quicker spool...OK. But at a given pressure and at given intake temp...say stock boost levels.....10 psi is still 10 psi isn't it? No difference in max hp at the dyno. Or am I missing something?
Jim
VR R1 FD
Old 04-09-2009, 08:20 AM   #27
SPICcnmFD
SPICcnmFD's Avatar
Not necessarily. If they flow better, then 10psi is more hp than the one that doesn't flow as good, which is why most singles make more hp at the same boost level as twins. Boost is just backed up flow that can't get through the engine.
1993 Rx-7 SM2 #11
At the local AutoX:
Speed for Sale shootout 2007:
A few laps at Barbers:
Old 04-09-2009, 10:09 AM   #28
Chadwick
Chadwick's Avatar
Also a more efficient turbo puts out less heat at the same pressure which will add to the HP gains.
93 RX7 BB (Race Car)
05 Silverado Z71
08 Mini Cooper
80 LS RX7 (for sale)
Old 04-12-2009, 09:41 AM   #29
Doc-1
Doc-1's Avatar
The car has a y-pipe, exhaust with high flow cat, RB dual tip, down pipe, commander stand alone ecu, 99 spec turbo's, a careful rebuild on the engine, K&N air filter and Mazdaspeed inter-cooler. I expected about 300 HP to the rear wheels with this setup at 10 PSI and got 294, 12 PSI got me 314, about right. Intake is stock
