Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > NRS Rotorsports
NRS Rotorsports www.nrsrotorsports.com (Canada) Ceramic apex & corner seals for rotary engine applications
Old 12-10-2008, 12:37 PM   #1
glassman
Premium Vendor
glassman's Avatar
glassman is on a distinguished road
NRS ceramic corner seals
NRS ceramic corner seals are on their way down under for extensive testing. Pete from Rice Racing will be testing the ceramic corner seals in conjunction with NRS 2mm 2pc apex seals. These will be installed in a new engine for Pete's SP. Other tests will be done later by Pineapple Racing including static drag tests comparing stock corner seals to the ceramic corner seals. Then of course they will go into an engine for further testing.
NRS hard faced c.s. springs will be used to ensure the tests will go the distance. Custom corner seals springs will be made also for testing as we know we can increase the pressure for better performance.
Hard faced c.s. springs heat treated with an extra little twist.
Mild to wild, street to strip, when you want to go fast and you want your engine to last, NRS Ceramics is the only way to go.
NRS Rotorsports
nrsrotorsports@shaw.ca
glassman is offline   Reply With Quote
