Old 02-23-2009, 10:13 PM   #16
YOU'RE IN OHIO AGAIN!!! LOL Just send the car out to me when you finish it and I'LL take it up the hill, HAHA.
dont you have a ping pong game to attend to?
Old 03-02-2009, 08:19 AM   #17
I have retired officially, but I choose to come out of retirement every now and then to beat our Deployment Commander, like just a little bit ago HAHA.
Old 01-31-2010, 12:48 AM   #18
rotaryracer
rotaryracer is on a distinguished road
Evans is very "cool" stuff. Possibly flammable. I've seen sprint cars pop a coolant line and since Evans is polymer based. Let's just say it was an exciting show. You couldn't see the car for the flame job. I am planing on using Evans in my race car this next season.
rotaryracer is offline   Reply With Quote
Old 01-31-2010, 01:43 AM   #19
Originally Posted by Gravity Fed View Post
those with V-Mounts, how well does everything "work" per say?
It sucks, I hate it, horrible idea
Old 04-05-2010, 11:52 PM   #20
local rally car guy running a turbo II used a truck radiator and a chevy thermostat
Old 04-06-2010, 09:52 AM   #21
Rearmount 8
Rearmount 8's Avatar
Rearmount 8 is on a distinguished road
If temps from the turbo is your concern why don't you try a rearmount? By doing that you'll keep the engine and turbo heat separate making the engine easier to cool. Just my $.02
To be the man you gotta beat the man...WOOOOO!!!
Rearmount 8 is offline   Reply With Quote
Old 04-06-2010, 11:29 AM   #22
too much stuff going on underneath the car. Hillclimbs equate to bottoming out
Old 04-06-2010, 12:50 PM   #23
Rearmount 8
Really, didn't realize that. Well good luck. Was just trying to help.
Old 04-10-2010, 11:38 AM   #24
1Revvin7
Turblown Engineering
1Revvin7 is on a distinguished road
I would run a turbo with a larger turbine wheel and a/r. This will help keep EGTs under control with very long pulls. V mount with a vented hood sounds like a good idea. I'm not sure if its mentioned, but water injection would also be a good idea. If you are really worried about underhood temps, we offer a lot of stuff to combat that.
http://www.turblown.net/store/index.php?categoryID=18
http://www.turblown.net/store/index.php?productID=55
http://www.turblown.net/store/index.php?productID=32
Rx-7 Turbo Kits, Engine Building, and Parts
www.turblown.net
1Revvin7 is offline   Reply With Quote
Old 04-11-2010, 12:55 PM   #25
FC3S Murray
frustrated!
FC3S Murray's Avatar
This LIM heat shield is very impressive! I wonder if it is 100% sealed? I have noticed that the very bottom portion of the LIM ALWAYS gets heat saturated even with certian heat shields.
255.00 is a bit steep BUT if it is 100% sealed it would be worth the heat restriction benefits.
Same pig, new soul
Old 04-11-2010, 07:18 PM   #26
thats rather shiny looking! Well see how the build comes together. Right now i have to finish the rally car before i get crazy on the other rx7. I might run pikes peak in 2011 in the rally car if im not co-driving for my friend. we shall see. thats over a year away so the hillclimb / road course car might be up and about.
Old 05-04-2010, 04:57 PM   #27
Tanj!
Tanj!'s Avatar
Tanj! is on a distinguished road
Something that hasn't been mentioned is ceramic coating. I know that Swaintech has a black body coating for radiators, intercoolers, etc that increase the heat dissipation. It's also used on the cold side of turbos. You can also gain some benefits from insulating the exhaust manifold and hot side of the turbo along with the downpipe. Also look at including an oil to water heat exchanger. That way you tie your oil and coolant systems together and are able to increase the volume of your heatsink and increase the cooling area. If you wanted to go the extra mile you can coat the exterior of the engine housings to either dissipate or hold in heat. I don't remember which Swaintech recommends.
Tanj! is offline   Reply With Quote
Old 05-04-2010, 09:09 PM   #28
Cp1
Cp1's Avatar
Heat-shields, properly designed air splitters, high water content coolant, you should take the time if its run especially hard to "fin" the oil pan and anything else you can air cool. read the book MAX BOOST by Corky Bell for great advice on designing baffles for air flow. just minimize the effects of the heat you are creating so go for heat wrapping and shields on the exhaust and then maximize the amount of cooling you can achieve by all those other things ive said.
Old 05-06-2010, 06:34 PM   #29
1Revvin7
The very bottom is sealed.
I recently had a customer do one of our turbine housing heat shields ( his turbo kit has his turbine close to the lim) and he picked up 7rwhp on a back to back test... Not too shabby...
www.turblown.net
