Old 10-19-2008, 11:42 PM   #16
BigTeddy
BigTeddy is on a distinguished road
FD and FC calipers are the same...
One Turbo At A Time
BigTeddy is offline   Reply With Quote
Old 10-24-2008, 01:18 AM   #17
Rotary#10
Rotorhead
Rotary#10's Avatar
odd question. any weight savings on the fd rotors, calipers compared to the fc rotors, calipers? maybe a pound or less hehe.
Currently running:
90 N/A GTUs..
Running project car
89 N/A GTUs in Black #2
10/6/18
Old 10-24-2008, 07:18 AM   #18
SpooledupRacing
Guest
Posts: n/a
OK then let me ask this question... WILL an FD caliper/pad/rotor combo fit on the front of an FC with no modification.
my guess is no and the ears on the sprindle sit out further on an FD to acomodate the larger rotor.
Old 10-24-2008, 07:25 AM   #19
No, the FD rotor will not fit without modification.
The brake caliper and brake pad will all swap no problem with any 4-piston front FC brakes.
Old 10-24-2008, 07:37 AM   #20
SpooledupRacing
Guest
Posts: n/a
right well the pads are the SAME part number.. the calipers I see physically they are the same
is it the hub that is different on the FD or is it the spindle spacing for mounting the caliper that would stop the bigger rotor from working?
Old 10-24-2008, 07:40 AM   #21
Yes, hub is different.
Remember, FC is MacPherson front while the FD is double wishbone.
Old 10-24-2008, 07:47 AM   #22
SpooledupRacing
Guest
Posts: n/a
I have yet to be under an FD.. thx for the info Ted.. I never knew that!
