Old 07-31-2008, 12:39 PM   #16
well they hold up better to the heat (I'm sure you saw some brittle lines during your teardown), are self lubricating, less likely to kink and doesn't tear as easily. The oil and gas tolerance is an issue but you really should try to keep your engine bay clean. If you are getting oil on the lines then you need to find the leak before the motor dies (same applies to the gas).
As far as the rice-a-roni look? I was planning on using multiple colors so others could see where the emissions vacuum lines are, along with the turbo, manifold and other engine lines.
I can save a few bucks but I've learned that cheaping out doesn't pan out for me. I end up replacing the same thing multiple times.
Old 07-31-2008, 01:36 PM   #17
Hmm, wow, that is an interesting idea! Ok, if i find silicone in BLACK, then I might do this later as well, when I have extra money i dont mind spending.
Old 07-31-2008, 01:53 PM   #18
so far the best prices are from the Baker's link in RETed's write-up.
Old 07-31-2008, 02:44 PM   #19
Comitatus
Comitatus's Avatar
Comitatus is on a distinguished road
Silicone comes in about any color you could want. All mine are black.
Can you find the rice in this picture?
Comitatus is offline   Reply With Quote
Old 07-31-2008, 03:50 PM   #20
classicauto
crash auto?fix auto
classicauto's Avatar
Yeah! What about that riced out bling bling hood prop huh?? lol
And as far as someone mentioning silicone being inferior to any type of other hose available - not a chance.
Provided its ACTUALLY silicone, and not that "silicone" shit that you buy in a box at Autozone - it will probably outlast your car.
My turbo oil drain is pure silicone, 5/8", and has been through 5 engines and over 35,000km's in total. I just pulled it off and its still fine......this is an OIL DRAIN, so its constantly full of 180* + oil and sits beside my 1500F exhaust manifold (although I wrapped it where its close)
Definetly no disadvangtes running it.
My vac lines are black silicone/viton mix. Bought through speedmachine back in the day (the fact that I bought them from Speedmachine should tell you how long they've been in service ) and have been on and off more times then I can count, and been driven as many miles as the oil drain.
Old 07-31-2008, 04:14 PM   #21
it has to be special silicone since it's an oil line?
I'm debating the tutti-frutti colors though. (help others see where the lines go? or make the car look like I want it to? tough choice)
Old 07-31-2008, 04:52 PM   #22
classicauto
crash auto?fix auto
Well I'm not sure. It IS for oil drain, so I'm sure its thicker/whatnot. More then anything its just oversized....5/8 silicone hose isn't exactly common. But regardless of whether its special or not - its silicone. Stinky ass silicone! (thats how I judge silicone quality, the stinkier the better .........seriously)
http://www.atpturbo.com/Merchant2/me..._Code=ATP-OIL1
Thats the drain hose. "hi temp silicone"
Old 07-31-2008, 05:20 PM   #23
ATP TURBO!!! THANKS. THat's within 30 minutes of me so I can go pick up some stuff there. I just couldn't, for the life of me, remember the name of the company.
