Old 06-26-2008, 04:53 PM   #16
Mike,
Check out this thread.. I took some pics and did a comparison between REW, RE, and 20B.
http://rotarycarclub.com/showthread.php?t=14
My goal of an adapter is to use stock set up such as oil filler neck, coil location (which isn't an issue for you), Throttle cable, wiring, greddy elbow, min. IC modification, etc.
Also, with the adapter, I could easily go from RE to 20B as they share VERY similar specs.
Old 06-26-2008, 06:17 PM   #17
sk8world
600rwhp club member.
Yeah, I remember those pics. I am interested in the adapter. Post some pics....
Posted by Chrispeed:
TB sizes.
13B-RE.... All 3 X 45mm
13B-REW/20B-RE.... Prim 1 X 45mm
Sec 2 X 50mm
All three have the same manifold bolt pattern but fitment will have some issues.
There's an open cavity on the bottom of the RE intake manifolds for the BAC valve passage that the FD's TB won't cover. Some use epoxy to fill in that area if not using the BAC valve.
Also the TB elbow for the FD and RE are not interchangeable.
Old 06-26-2008, 10:20 PM   #18
I'll take some pics this weekend..
My adapter will cover up the BAC valve passge and will mate with FD TB perfectly!!
This way you could keep most of FD wiring harnesses such as TPS. Only thing you might have to relocate is the Air temp.. Which I think you already done that.
Old 06-27-2008, 12:33 AM   #19
sk8world
great.. Waiting for pics..
Phil, if you talk w/ Luis see if my center section is ready? Thanks,
Old 06-27-2008, 02:07 PM   #20
He said he's not done.. He said his balancer is damaged and unable to completely balance your stuff. He said it would be little bit longer.
I'll take some pics tomorrow as if the weather is bad, All I'll be doing is working on my engine(s).
Old 06-27-2008, 03:39 PM   #21
sk8world
I just got off the phone with Luis.. He droped a gauge and had to order another. I just have to clean up everything and its ready to go back together. Need to order seals and such now...
Old 07-01-2008, 08:02 PM   #22
busted7
busted7 is on a distinguished road
Looking great Mike glad to see you getting closer and good luck!
busted7 is offline   Reply With Quote
Old 07-02-2008, 01:13 AM   #23
sk8world
Thanks, But dont let me fool you... I just finished spending another 2.5 hours porting and still have another night of porting to do. I need to order my gaskets, seals, another fuel pump, wastegate, RE fuel rail, send inj's of for cleaning, do some rewiring on harness, and waiing to here from Phil about an adapter for RE mani to REW TB. thats it..LOL
Old 07-02-2008, 09:13 AM   #24
Opps... Totally forgot about that.. I'll try to remember tonight and take some pics..
I been having problems with the 8 and totally forgotten about taking pics. Also email me instead as I don't check this thread that often.
PHIL
Old 07-03-2008, 07:10 AM   #25
Mike,
Here are few pics of the adapter.
As you could see, it bring the length of the UIM to the same length of REW UIM. THis should clear oil filler neck and use IC pipings for REW. Also, be able to use the REW TB, which means could use the Greddy elbow.
Old 07-03-2008, 07:32 AM   #26
lt1_fd3s
WNC Tour Guide
lt1_fd3s's Avatar
sorry to thread hi-jack for a moment, but phil, you make and sell the adapters? if so, then i'll want to find me an RE manifold
Old 07-03-2008, 11:52 AM   #27
That's the plan of designing that adaptor.. to sell I won't be making much.. And whatever I make from it, it would go toward this forum...
Its going to be around 400 a piece unless we get a TON of orders... as its going to take a quite of bit of machining..
Good thing about this is you get to use all REW stuff.. 20B TB and REW is pretty much has the same spec. Except 20B, you have to use 20B TPS. This way, you could keep everything the same
I'm also planning to use this on FD/20B swap. Did my calculation and everything should fit and make the conversion simpler.. and still use FD TPS and TB.
Old 07-03-2008, 12:25 PM   #28
lt1_fd3s
WNC Tour Guide
lt1_fd3s's Avatar
nice...look forward to seeing ur project phil...and sorry for the short thread hi-jack sk8world
Old 07-03-2008, 02:58 PM   #29
sk8world
great looking work.... Pm me or post up and let me know how long to get one.
Old 07-03-2008, 11:52 PM   #30
sk8world
ports
So here are my final ports. Pics show Mine, BDC's and a stock one.
