Old 05-03-2008, 02:36 AM   #16
-xlr8planet-
-xlr8planet-'s Avatar
Im doing the water jacket mod. Will post pics tomorrow.
Im doing a crappy job BTW. Doing it by hand its quite hard....
it does the job anyways, even if it does not look pretty
Old 05-03-2008, 09:28 PM   #17
-xlr8planet-
Old 05-03-2008, 09:50 PM   #18
Chadwick
Chadwick's Avatar
Another place to look is the flashing left over on the irons from the mold. I go through and clean all of the excess metal off to smooth out the flow.
Dan
93 RX7 BB (Race Car)
05 Silverado Z71
08 Mini Cooper
80 LS RX7 (for sale)
Old 05-03-2008, 10:07 PM   #19
-xlr8planet-
Just for the record:
to do this properly you gotta have great pulse ... or a CNC machine up your ass
Old 05-08-2008, 06:39 AM   #20
Barry Bordes
Barry Bordes's Avatar
On my next set of housings I am going to try a wood router and carbide bit. Routers have great height adjustments.
Barry
GOD the Incomprehensible Obvious (www.frksj.org)
Old 05-09-2008, 10:59 AM   #21
Barry Bordes
Originally Posted by My5ABaby View Post
This heat problem also leads to cracks around the spark plugs when someone takes the revs too high on a cold engine. Just a side note...
I never load the engine cold. I wait for 80˚C before boosting and always use at least a 2 minute cool-down before shutting down (a habit from working on turbine engines which is their requirement).
So I think the cracking has to be just high heat from poor cooling in that area.
The housing with the cracks didn't have the 3rd gen housing cooling mods, but both housings were lifting in the spark plug area. Notice the carbon stains to the side of the hole.
I have a theory that this lifting of the apex seal and jamming of the triangle tip is what breaks the seal in some cases without detonation being present. I found one unbroken but cracked apex seal. It was cracking from the bottom! I visualized them breaking from the top.
Barry
Old 06-16-2008, 10:13 AM   #22
Barry Bordes
I am thinking that we need to increase the temperature in the carbon stained areas and drop the temp at the plug so I am going to try this.
The slotted spoke will concentrate the cooling conduction effect to the plug boss but not to the housing.
Maybe added grooving perpendicular to water flow would also help.
Barry
Old 06-18-2008, 07:22 PM   #23
damn, i see what you did. So, how safe is it to remove so much of that metal? What boost do you normally see?
Old 06-22-2008, 06:43 AM   #24
Barry Bordes
Normally 14 but up to 20 psi. I checked out a 16X and a rx8 housing for the latest cooling mods. They are similar. But they remove most of the fin that could be used to cool the plug bore.
Barry
Old 06-27-2008, 11:09 AM   #25
Very Interesting Barry! I would love to see the results of this mod. Maybe we could get one of the CNC guys to program this in and mass cut the housing... I also like the idea of parallel groves vs. the perpendicular grooves I've seen before.
Old 07-11-2008, 05:50 AM   #26
Barry Bordes
This will be my next test. Presently I am running the enlarged passages around the sparkplugs with the Mazmart pump.
Barry
Old 07-16-2008, 08:21 PM   #27
Dan
You actually release more thermal energy with turbulant flow (not saying removing the flashing is a bad thing, just that it would be better to cause turbulence in the coolant stream so that lower energy coolant comes in contact with more surface area).... did I make any sense at all?
Old 07-21-2008, 10:46 AM   #28
Barry Bordes
Yes it does. I would like to use computer heat-sink type devices on the flat surfaces next to the plugs.
Barry
Old 07-22-2008, 08:34 AM   #29
Barry
Fin type (copper)?
Old 07-25-2008, 09:28 AM   #30
Barry Bordes
Fin type (copper)?
To minimize dissimilar metal corrosion we should stick with aluminum.
Barry
