Closed Thread
Old 03-09-2016, 03:32 PM   #1
Boost vac boost vac boost vac boost vac..... see where I'm going with that?
Can you explain even further...
RETed is offline
Old 03-09-2016, 03:35 PM   #2
TitaniumTT is offline
Old 03-14-2016, 04:00 PM   #3
Barry Bordes
Barry Bordes's Avatar
This is for the guys building their own engines.
An engine built anywhere in the world will be capable of making approximately the same power if the builder uses good tolerances and has a close attention to detail.
This includes engines built by Jonathan, Carlos, Alex, Tom, Brian, Howard, Peter and you Ted....(if you don't see your name I can add it!)
There should be no hero worship for anyone special. Forget the hype.
Your simple practice should be...
1- make the best possible sealing points... hence the zero-clearance side seals.
2- give the apex seals a flat surface to run-on using something like my sparkplug area cooling mod.
3- Make the AFR's spot-on with help from something like my free Excel AFR Corrections Program or any other autocorrect system.
4- And probably the toughest... center the combustion peak-pressure around 45 degrees atdc. This is where most people fall short... they go for what is called a safe ignition map.
If you follow these simple ideas you will have the highest horsepower possible at what ever boost you run, even NA.
Barry Bordes is offline
Old 03-15-2016, 10:04 AM   #4
knonfs
knonfs is on a distinguished road
Barry, what do you mean by #3?
Make sure its not too lean/rich under boost? all parts of the map?
knonfs is offline
Old 03-19-2016, 04:18 PM   #5
Barry Bordes
knonfs,
This is what the Excel program looks like.
send me a PM and with your email and I can send you a copy.
Most people don't understand the importance of an ideal mixture and it's to improvement to the burn rate.
Then on the second folder you take your corrected base map and check it any anomalies.
Barry
Old 03-16-2016, 01:30 AM   #6
Too complex...
1) Strap car on dyno
2) Adjust fuel maps
3) Adjust ignition timing maps
4) Go back to #2 and #3 until you're satified
This is how I tune my cars for highest horsepower, even NA...
Oh, here's a secret: this works for piston engines too...
RETed is offline
Old 03-16-2016, 08:08 AM   #7
Barry, could you elaborate on #4
Old 03-19-2016, 08:26 PM   #8
Barry Bordes
Brian,
This screenshot is a little hard to make out but it shows that the closer to 45 degrees (in the 5000 to 8000 rpm range) the more peak pressure is made.
Notice that each ignition event is different and that the best pressure point can be determined comparing pressure to degrees for peak.
Location is the on the bottom chart and in this example we would add degrees of advance as noted then retest.
Barry
Old 03-21-2016, 05:10 PM   #9
chibikougan
chibikougan's Avatar
Happy Bday the other day Barry.
chibikougan is offline
Old 03-16-2016, 12:17 PM   #10
ninesixtwo
sumdumguy
ninesixtwo is on a distinguished road
Aiming for a certain peak chamber pressure vs a given crank angle is fine in theory as most people don't have access to in-cylinder pressure monitoring so its kind of a moot point. In practice, OEM level calibration involves monitoring the crank angle at which 50% of the combustion charge has been consumed. The optimal point for CA50 has a 2-3 degree range for any engine, whereas peak cylinder pressure can be deemed "optimal" for a range more than twice that.
HKS T04Z Bridgeport FD3S
ninesixtwo is offline
Old 03-19-2016, 06:49 PM   #11
Barry Bordes
ninesixtwo,
Actually that is the approach that I have been working on. The TFX program also does Fraction Burn and Combustion Rate.
Anything that we can do to increase burn rate is beneficial....
One thing that can be done without internal mods (hint) for instance would be experimenting with ignition split and it's effect on burn rate.
The saw tooth angle of burning gases and the fraction burn shown below have been used to make definite increases.
Barry
Old 03-24-2016, 10:46 AM   #12
Barry Bordes
ninesixtwo,
Barry
Compare the above Fraction Burn and Combustion Rate rate to the result achieved in this much later experiment.
You can see the dates of each test in the top left corner.
This total increase happens by many very slight incremental improvements.
Barry
Old 03-23-2016, 06:04 AM   #13
Slides
I'm a bit sceptical about side seal vibration causing apex seal failure, the pressure differential across the long sides combined with deposits would mean a massive frictional force to overcome sliding back and forth in the side seal grooves, with a minuscule area at each end to provide motive force via gas pressures and very small distance for the seal to build up momentum.
Thanks for your continued input Barry.
Edit: couldn't let this go, and wanted to give a basic explanation for those playing at home.
The only way motion of a rotor could push/turn a side seal "backwards" (remembering that the oil seals have directional springs as well) was if you had entirely different e-shaft/seal/rotor design (leaving large dead zones on the sides of the rotors) which allowed the side/corner seals on one side of the rotor to be inside the tooth contact radius of the rotor gear. Not practical or desirable.
You can see this simply for yourself by drawing a rotor and stat gear and taking a radius from the point of tooth contact (the stationary point and centre of motion at any time) to anywhere on the rotor, only points lying inside the rotor gear can have a back/forth motion relative to the side plate (through an engine cycle). Even then it would only present a problem if the majority of an independently moving seal part was inside an arc of radius equal to teh gear radius from the tooth contact. That is you could have an engine design with circular oil control seals inside the rotor gear radius (on the off-gear side of the rotor) with the same directional spring design as ours without a problem.
Slides is offline
Closed Thread
