Closed Thread
Old 05-12-2015, 07:12 AM   #16
BrewerBob
BrewerBob's Avatar
BrewerBob is on a distinguished road
Originally Posted by silverfdturbo6port View Post
My next door neighbors 13b 6 port. Webber carbs, header. Pretty fun to drive!
Looks to me like there's room for a third rotor.
Originally Posted by mazpower
Wherever there is meat to be rubbed, smoked and cooked...wherever there are mountain roads that need slaying with his trusty Dakota, Batwing Bob is there, his skin flapping in the wind, casting a shadow over the populace and giving them comfort
Originally Posted by Fendamonky View Post
Bawbs got 99 problems, but being old apparently ain't one
BrewerBob is offline
Old 05-12-2015, 07:15 AM   #17
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
I think the SA tranny will get the shifter closer to where you need it. Or maybe you can
futz with the tail shaft to shorten it. Either way you will need a custom driveshaft anyway.
t_g_farrell is offline
Old 05-12-2015, 12:53 PM   #18
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Originally Posted by Brewerbob View Post
Then just drop everything lower and further back a la Brian style.
I'm going to try, but there is not a lot of room to play with. I hate to move the engine too far back as the weight is already biased toward the rear.
The SA trans will only move the shifter about 2 to 2.5 inches, an RX8 trans would move it 3.5 inches. Either way it is far short of the 8.5 inches that it probably needs to move to keep the shifter in the stock position. I am a little worried on tail shaft length though as the drive shaft is already pretty short. If I get the driveshaft too short I'm likely to have vibration and U joint binding problems.
GySgtFrank is offline
Old 05-13-2015, 12:19 AM   #19
GySgtFrank
GySgtFrank's Avatar
Doing the trial fitting. I'll try to document what I ended up doing as thoroughly as I can, in case anyone else ever wants to give this swap a go. I haven't been able to find any build threads on this swap that were very complete. Lots of questions on how others did it, but they didn't share.
Things are even tighter than I thought. I needed some room up front as the front of the rotary is more squared off and wider than the 1500.
1. original front cross member:
1. original crossmember by Kevin Frank, on Flickr
2. sliced, hammered down, and re-welded:
2. sliced and welded by Kevin Frank, on Flickr
3. Trimmed and completed front cross member:
3. completed crossmember by Kevin Frank, on Flickr
Gained 2.25 inches of room up front so I can set the engine down between the frame rails. It looks like I'm going to have to do some clearancing on the rails and the heater box area to the back of the engine as well.
Old 05-13-2015, 05:21 AM   #20
Slides
Are the shifter distances you are talking about with the shifter shaft shortened and shifter housing moved forward of standard on the mazda boxes? Everyone does it to rx7 boxes here in aus to fit into the older rx bodies.
Slides is offline
Old 05-13-2015, 11:02 AM   #21
GySgtFrank
GySgtFrank's Avatar
Yes, that is what I am contemplating. I know I'm going to have to shorten the shaft and move the box quite a bit, because I would like to keep the shifter in the stock position. We'll see for sure how much I have to move it once I get the engine settled into final position. Hopefully I won't run into problems shortening it as radically as it appears that I will need to.
Old 05-13-2015, 04:45 PM   #22
GySgtFrank
GySgtFrank's Avatar
After more trial fitting, it has become apparent that the engine will not go in there without removing the shelf for the heater box and the ducting underneath it (The back of the engine block hits the ducting). I went ahead and took the battery tray out as well. This provides a lot of room to the rear. You could put a straight six in there with this part out. In fact one person did put a Jaguar DOHC six in one. It should also make taking the engine and transmission in and out a WHOLE lot easier.
original heater/battery tray:
heater box and battery tray - original by Kevin Frank, on Flickr
heater/battery tray removed:
heater box and battery tray - removed by Kevin Frank, on Flickr
Once I have the engine where it needs to be I'll look at rebuilding a spot for the heater. I can do without A/C if I have to, but a heater is important, even if it's only to defog the windshield. The battery will be relocated elsewhere.
Getting that shelf out wasn't easy. I had to drill out a bunch of spot welds, make cuts with the plasma cutter, and do the fine cutting with a cut-off wheel so that I didn't damage something I needed.
Old 05-14-2015, 04:06 PM   #23
GySgtFrank
GySgtFrank's Avatar
Another necessary modification. The permanent transmission crossmember is too high to slide the transmission into the tunnel. Technically all it really needed was to be notched so the transmission would clear. However a non-removable crossmember makes it a royal PITA if you need to drop the transmission. With the permanent crossmember you have to pull the engine and transmission in one unit to get it out of there. I went ahead and removed the center section of the crossmember and will fabricate some plates for the ends and bolt the modified section back in so that I don't compromise structural integrity.
original:
trans crossmember - original by Kevin Frank, on Flickr
removed:
trans crossmember - removed by Kevin Frank, on Flickr
Now to try fitting it back in there. It doesn't appear that the transmission tunnel is going to require much modification to fit the NA transmission. I would imagine that the turbo transmission would be a different story as the NA trans barely fits.
Old 05-14-2015, 07:14 PM   #24
GySgtFrank
GySgtFrank's Avatar
... and engine/trans in place about where it has to sit. I still need to notch the lower rails a little bit to allow the engine to sit a little lower, not as much as I was afraid that I would though. About 1/2 an inch on the passenger side rail should do it.
engine placement 1 by Kevin Frank, on Flickr
engine placement 2 by Kevin Frank, on Flickr
engine placement 3 by Kevin Frank, on Flickr
The reason I say that it has to sit here is that it lines my exhaust ports up with the small opening for the exhaust to work it's way under the car. The engine is offset to the right (passenger side) by about an inch to line up with the differential input for a straight line shot with the driveshaft.
engine placement 4 by Kevin Frank, on Flickr
Needless to say the coolant filler neck is going to need to be modified and shortened.
I will need to cut and box the upper part of the passenger foot well to allow me to use the stock lower intake manifold. Just not enough room without doing it that way. Shouldn't be a problem as nobody has their feet or legs in that spot anyway. It's just wasted space, and space is at a premium with this swap.
The shifter definitely has to be moved forward about 8.5 inches, or more. (edit: engine back out, measurement made - 9 3/8")
Good news is that the end of the transmission tail shaft is only about 3.5 - 4 inches further back than the original 1500 transmission. That shouldn't cause too many problems, I hope.
Old 05-17-2015, 09:38 PM   #25
GySgtFrank
GySgtFrank's Avatar
Here's my solution to a really short shifter. The first picture I had to steal off the internetz as I forgot to take a "before" picture. The FB box in the rear is very similar to the FC box that I have. The shifter box actually sits behind the tail shaft. This is a no go in my application.
So I moved the box forward 9 inches to put it in the stock MG shifter location.
short shifter 2 by Kevin Frank, on Flickr
short shifter 1 by Kevin Frank, on Flickr
I've seen prettier renditions of this, but this is how I did it.
The mount was cut off right next to the box and I used the side cover plate to attach a mount using the original rear bolts, one side bolt, and the locator pins. The shaft for the shifter was cut 9 inches and the roll pin hole re-drilled. (I had a machine shop do this for me as I always get the hole off center when I try to drill a round rod). The shaft is not hardened toward the rear so drilling it wasn't a problem. I also had to do a little "massaging" with a grinder on the tail shaft housing. This was necessary to get the box to sit all the way forward against the opening that the shifter shaft exits the case.
It works, but it seems a little stiff right now. Could be that the shaft is binding a little bit which should work it ways out as it gets used or it may be that the RTV I used between the box and the case is pushed up against the shaft.
It does go in and out of all the gears just fine, so I'll give it a try as is.
Right now I'm working on notching the lower frame rails to give me enough room to drop the engine a little lower in the frame.
Old 05-17-2015, 10:09 PM   #26
mattallac
mattallac's Avatar
thats a cool trick , looks great
mattallac is offline
Old 05-21-2015, 06:48 PM   #27
GySgtFrank
GySgtFrank's Avatar
Thanks mattalac. Plenty of people have shortened the shifter before, but they usually didn't have to move it quite that far. The better way would have been to weld the box to a mount. I don't have a machine that will weld aluminum, so I went this way.
After about five days of work I finally have the frame modifications finished to make the engine fit in there the way I want it to. It took a while as the mods were more extensive than I thought they would be at first.
You can see the original frame in the original crossmember picture above. (as usual I forgot to take a before picture)
modified:
Frame mods 1 by Kevin Frank, on Flickr
frame mods 2 by Kevin Frank, on Flickr
The rotary is a lot wider at the bottom and made it necessary to widen the rails to set it down low. All the other threads I've seen on this set the engine above the frame rails, with attendant problems of the oil pan rails occasionally hitting. Not to mention what it does to the center of gravity.
I welded in two 1/2 thick plates to the outside of each rail between the body tub and the suspension points. Excessive, but it covered the existing flange on the bottom of the rail perfectly. I then trimmed one inch from the inside of each rail and welded 1/8th inch plate to close off the inside. I had to notch the driver's side rail another inch or so for the oil cooler line and the oil bypass sticking out the side of the bottom middle iron. This ended up being the entire width of the rail except for the outer layer. The front crossmember had to be further trimmed to give me enough room to push the engine a little further forward. After taking part of it off I closed it in with more 1/8th inch plate. I then welded in 8 studs and crush tubes along the sides and front for a skid plate/ frame stiffener. It will bolt underneath to tie the entire front suspension together. It will be considerably stronger and stiffer than the original.
Most people don't go this far for the swap, but I'm kind of anal about chassis stiffness and a low center of gravity.
Old 05-25-2015, 07:09 PM   #28
GySgtFrank
GySgtFrank's Avatar
The fruits of my weekend.
After much trial fitting and head scratching, by Jove! I think I've got it. Engine mounts that is. There wasn't enough room to use the FB or FC stock pads so I improvised with polyurethane captured mounts originally intended for use in rear suspension lower swing arms.
engine mounts 3 by Kevin Frank, on Flickr
engine mounts 2 by Kevin Frank, on Flickr
I will extend the front mounting plate over to each and bolt it to the top of each polyurethane mount. There's not a lot of give in this setup so engine placement is going to have to be pretty exact as far as engine angle vs. pinion angle before I weld it up. I used the bolt on approach because if I had simply welded the front plate to the mounts interference from the tabs would have made it nearly impossible to pull the engine without removing the front plate from the engine.
Old 05-25-2015, 07:57 PM   #29
banzaitoyota
banzaitoyota is on a distinguished road
looking good
My deuce
banzaitoyota is offline
Old 05-28-2015, 03:19 PM   #30
GySgtFrank
GySgtFrank's Avatar
Originally Posted by banzaitoyota View Post
looking good
Thanks. Getting there. It's taking a little more than I thought at first to get it where I want it.
Engine support bar done and the engine is mounted. Lots of fiddling to get bracing in there without interference. As you can see, not a lot of room to work with. This was as low and right as I dared to go. I plan to modify the oil pan/pickup to make the sump shallower and longer. I have full access to the bottom of the pan, but it does hang pretty low with the engine this far down.
engine crossbar 2 by Kevin Frank, on Flickr
engine crossbar 1 by Kevin Frank, on Flickr
Closed Thread
