Old 11-21-2013, 01:16 PM   #16
Haha Estevan. Mine isn't nearly as badass as yours, but it should run ok
Old 11-21-2013, 09:32 PM   #17
estevan62274
counting down till DGRR
estevan62274 is on a distinguished road
No worries man, hope to check out your RX-8 at DGRR 2014
-74 RX-4
-84 REW GSL-SE
Past rides
-05 REW Swapped RX-8
-93 FD base
estevan62274 is offline   Reply With Quote
Old 11-22-2013, 05:41 AM   #18
Sounds good man.
Old 11-22-2013, 09:36 AM   #19
FC Zach
FC Zach's Avatar
Very Nice!
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 11-22-2013, 09:39 AM   #20
Thanks Zach.
Old 11-22-2013, 05:04 PM   #21
Figured I would share an exhaust clip...
Old 11-22-2013, 05:10 PM   #22
JL1RX7
Didn't sound bad. Have any luck with the intake issue yet?
Old 11-22-2013, 05:12 PM   #23
Its been cold and wet here in STL so no go so far. Should have new plugs/wires/coil next week so that is when the real fun begins. Will probably ghetto compression check it too while I am at it.
Old 11-22-2013, 05:15 PM   #24
JL1RX7
Considering thats the Mazda standard of motor replacement. Change the plugs/coils. If that clears up the issue then all good. If not replace motor.
Old 11-22-2013, 05:17 PM   #25
Haha yeah. I have a forum member lined up for a rebuild if thats the case. I still have a hard time believing its low compression considering how easy it starts and how well it drove. My past rx7 experience said low compression = PITA to start.
Old 11-22-2013, 05:21 PM   #26
JL1RX7
For some reason the Reni doesn't play like other rotaries. Usually hot start is the sure fire kicker. Getting the uprated starter, changing the plugs and coils like underwear, and running any oil other than 5w30 is the key to keeping them playing nice.
But your right normally hard starting sluggish throttle and hunting idle are the normal death notes.
Old 11-22-2013, 05:37 PM   #27
Well nowhere near a definitive test, but I let this car idle the other day for about 15-20 minutes. Then I shut it off, waited 5 minutes, and cranked her back up. Started almost as easy as initial startup. Previous owner stated Mazda two different times told him low compression and wanted $6k for a new motor since the mods voided the engine warranty.
Old 11-22-2013, 05:50 PM   #28
JL1RX7
Man what did he do to it?
Old 11-22-2013, 06:25 PM   #29
Old 11-22-2013, 06:26 PM   #30
JL1RX7
No wonder it is blown! Reni's don't like turbos.
