Old 04-14-2008, 04:46 PM   #1
Chassis Overhaul
I'm planning on redoing anything involving the handling of my vehicle. This includes:
- braking system
- suspension
- mounts (tranny, engine, diff, ??)
- bushings
Basically, I want to replace any wear item.
Here's the list of what I have so far (listed as: Part, Quantity needed, and Part #).
Is there anything missing?
Rear Suspension
Stopper-Rear Damper Rubber 2 FB01-28-014
Spring Rear Damper Sheet 2 FB01-28-040
Mounting-Rear Damper Plate 2 FB01-28-050
Rear Damper Stopper 2 FB01-28-030A
Rubber-Rear Damper Bushing 2 F044-28-015
Rubber-Rear Damper Bushing 2 F044-28-013
Rear Damper Plate Set 2 FB01-28-020
Rear Damper Spacer 2 FB01-28-025
Rear Stabilizer
Stabilizer Rear Bushing 2 FB43-28-156A
Rear Lower Arms & Sub-Frame
Rubber-Rear Lower Arm Bushing 2 FB01-26-220
Pillow-Rear Lower Arm Ball 2 FB01-26-230
Seal-Rear Lower Arm Rubber 4 FB01-26-250
Lower Arm Bushing 4 FB01-28-460
Sub-Frame Rubber 2 FB43-28-840
Mounting-Differential Rubber 1 FC01-28-890 / FB01-28-890C
Rear Axle
Lower Arm Stopper 2 FB01-26-335
Seat-Bearing Housing Rubber 2 FC01-26-410
Front Suspension Mechanicsms (1-M13)
Stop Bumper (Bound Bumper) 2 FB01-34-111A
Spring Cushion (Rubber Sheet) 2 FB01-34-012
Spring Seat 2 FB01-34-341
Damper Cap 2 FB01-34-019
Bump Stopper 2 FB01-34-312
Mounting Rubber 2 FB01-34-380
Rubber Lower Arm Bushing 2 FB01-34-460
Rubber Front Bushing 2 FB01-34-470
Lower Ball Joint 2 FB01-34-550
Crossmember and Stabilizer (1-D14)
Stabilizer-Front Rubber 2 FB43-34-156
Brakes
Front Rotors 2 FB05-33-251A
Back Rotors 2 FB04-26-251A
Front Calipers 2
Rear Caliper (L) 1 FB05-26-710B
Rear Caliper (R) 1 FB05-26-610B
Differential
Mouting-Differential Casing Rubber 2 FB01-28-890C
Engine/Tranny
Front Eng Mount 2 FB01-39-040A
Trans Mount 2 FB01-39-340A
