Old 01-15-2012, 12:08 PM   #1
cturbo28
cturbo28's Avatar
cturbo28 is on a distinguished road
SSM RX7 Build
Anyone interested in seeing my FD project that I have been developing over the past two SCCA autocross seasons?
General Specs:
1993 base model FD.
Engine:
Stock re-man engine with about 6K on it.
Custom Precision Turbo HP5530SP with .78 AR T3 exhaust housing twin scroll.
Custom V-mount intercooler
Greddy elbow
Custom V-mount cross flow radiator "Afco"
Custom CAI 4"
Custom HPP Delrin engine mounts
Exhaust:
Custom 3.5" downpipe
Custom short runner turbo manifold divided with twin wastegates
Custom stainless flex joint
Custom 4" exhaust from DP.
Magna Flow 4" round exhaust
Custom 4" tip adjustable angles for sound restrictions
Fuel:
Bosch 044
Custom 5 gal aluminum cell
Custom fuel fill cap mounted on passenger side
-6 AN fuel lines
KG fuel rails
FPR aeromotive import style
Custom surge tank in-tank
ID2000 injectors
Electronics:
Haltech PS2000 tuned by Ludwig lmsefi.com
Haltech EGT's via CAN hub TC2 lmsefi.com
Haltech SSR for Electric water pump
AEM exhaust manifold pressure sensor lmsefi.com
AEM boost control pot lmsefi.com
Greddy boost gauge
NGK wideband lmsefi.com
LS2 coils (soon to be AEM)
Magnacore spark plug wires
NGK racing plugs (ouch) 10.5's
Greedy racing plugs 11's lmsefi.com
Suspension:
Custom valved Koni 28's aluminum body by Pro Parts
Custom spherical bearings on all pick up points.
Tri point front sway bar
Stock rear sway bar
Custom upper control arms ( adjustable on the car!) new design in progress
Custom lower front ball joint, replaced stock with spherical.
Rx7 store toe links and rear trailing arms
Shoes:
CCW 18x11 7.5 backspace fronts with Hoosier 315/30/18's
CCW 18x12 7.5 backspace rear with Hoosier 335/30/18's
Rain set up FNO1R-C 17x10 +35 All four 275/40/17's Hoosiers
Trans and stuff:
Stock trans with short shifter
Stock re-main flywheel
ACT pressure plate
LWFW (TBD) not installed at this time
TN clutch 4 puck solid disc
Kaaz diff set at 66%
Stock PPF
Delrin diff bushings
HPP racing diff brace
Custom HPP torque v-brace
4.10, 4.77, 4,44 gear ( trying to test to see which on is best for the car.
Aero:
Custom front splitter Aluma core ( made by Tomsn16)
New Ciro racing design rear wing.
Body:
Pettit rear flares
Custom English wheel rolled front fender to tuck the 315"s
Awesome bare custom hood with cut out for IC
Racing shield aluminum seats with custom aluminum mounts
Sparco steering wheel
Misc specs:
2510 lbs without driver
Relocated ABS system
Hawker battery relocated
Dyno sheet will be posted soon
SW20 EHPS mounted behind passenger seat.
EWP Craig Davis 7/21/12 installed
This is a picture of the last SCCA race last year held at our own Nashville Super Speedway in October.
Instead of flooding the Thread will a bunch of pictures I will just ad pics that people are interested in or request.
CT
93' FD
cturbo28 is offline   Reply With Quote
