Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Full Function Engineering
Full Function Engineering Full Function Engineering based out of Phoenix, AZ.
Old 01-30-2012, 09:52 PM   #16
reese.leblanc
Doing my own thing
reese.leblanc is on a distinguished road
Did you determine if the current primary rail will work on the 13B-RE? I'd like to order one if it does.
reese.leblanc is offline   Reply With Quote
Old 01-30-2012, 10:05 PM   #17
fullfunctioneng
Triggers R Us
fullfunctioneng's Avatar
fullfunctioneng is on a distinguished road
Unfortunately it is still in transit. We'll let you know once we get it all sorted out.
www.FullFunctionEng.com
S4, S5, and 13B-RE trigger kits now available!
Click Here!
FD trigger kits now available!
Click Here!
fullfunctioneng is offline   Reply With Quote
Old 02-18-2012, 11:57 PM   #18
reese.leblanc
Doing my own thing
FFE PRIMARY RAIL FITMENT UPDATE
Ok. Pictures will have to wait until the next couple of days since my camera decided to go screwy on me, but here is the news a few of us have been waiting for.
The current primary rail DOES work on a 13B-RE. After talking to Aaron, I was the new guinea pig for verifying the fitment. I am currently running a stock secondary rail, so I bought the appropriate -6 O-ring to -6 fittings and two -6 to 90* barb fittings to allow me to connect everything.
At first, I pulled my diffusers out and cut off the lower section, intending to just use the upper half as a spacer. Then I simply swapped the lower O-rings on my Bosch injectors for the Denso cushons and installed the rail. When I fired the car up, I had a high idle that hadn't been there before. I pulled everything apart and also pulled my diffusers out to check them as well. It turns out that the grommets on the diffusers weren't in the best shape, and I guess that pulling them out in the first place made them worse.
Not wanting to have to source new grommets, I decided instead to put one extra Denso cushion in each primary injector port to take up the space left by leaving the diffuser out. I reassembled everything and tried again. SUCCESS! No leaks (fuel or vacuum) to be found. I'm pretty certain that leaving your diffuser in and using just the one cushion will work fine, but I would check the grommet while you have everything apart.
Cliff's Notes: The FFE primary rail DOES work on the 13B-RE.
Many thanks to Aaron for being prompt with getting the rail to me overnight as requested as well as having great customer service. Definitely continue to support a great vendor making incredible products!
Old 03-21-2012, 02:49 PM   #19
motormanalpha
Over rev'd, under torqued
motormanalpha is on a distinguished road
Hello Full Function Guys,
Can we have another progress update? Especially for the secondary rails?
Thanks!
mma
motormanalpha is offline   Reply With Quote
Old 04-04-2012, 02:30 PM   #20
fullfunctioneng
Triggers R Us
These are taking way longer than expected and we do apologize. Here is some progress though on the FD secondary!
Click Here!
Click Here!
Old 04-04-2012, 11:16 PM   #21
motormanalpha
Looking good! Let us know when it's a product!
Old 05-17-2012, 08:02 PM   #22
fullfunctioneng
Triggers R Us
Full Function Engineering fuel rails are finally here!
To save everyone the hassle of a group buy we decided to do a limited time introductory pricing on rail sets with or without Injector Dynamics injectors.
To those who already purchased our primary rail: the price you paid will be deducted from the kit you want!
Rail Features
1/2" Bore - Suited for high horsepower needs
O-ringed end fittings - No more Teflon tape/worn threads!
Centering Spacers - Ensuring injectors are centered for no air/fuel leaks
Stainless Hardware - High strength/corrosion resistant
Rail Fitment
13B-REW
Primary Rail
48mm or 34mm injectors
Secondary Rail
48mm - (requires our block-off plate)
34mm (w/ or w/o emissions)
In Blue:
Or Black:
13B-RE
Primary Rail - same as REW
Secondary Rail
48mm (w/ vacuum tubes)
48mm (w/o vacuum tubes)
34mm (w/ vacuum tubes)
34mm (w/o vacuum tubes)
60mm
Available in black or blue:
Reference:
ID725/1000 = 48mm
ID850/2000 = 34mm
Bosch Style 1600 = 60mm
13B-T (Coming June 1st)
PRICING:
All prices are plus shipping and bare rail.To those who already purchased our primary rail: the price you paid will be deducted from the kit you want!
Primary - $115
Secondary - $140
Combo - $245
PM us for pricing including injectors!
Introductory pricing ends June 15th!
Accessories
O-ringed LIM 12mm adapter (replaces denso donut) - $6 ea.
13B-REW ACV Block-off Kit - $10
-6AN to -6AN ORB Union - $9
Click Here!
Click Here!
Old 05-18-2012, 12:24 AM   #23
Looks ABSOLUTELY FANTASTIC guys.... LOVE it.
You KNOW I'm first on the list for the 13B-T rails And what color please
About a week late though... I just ordered all the fittings I would need to adapt the stock rails... oh well, they'll get used eventually.
Qustion on the Cosmo stuff.... vaccuum tubes?
Old 05-18-2012, 12:27 AM   #24
Incidentally. For anyone who hasn't installed aftermarket injectors in the plates/LIM before.... see the little blue adapters in this pic
TRUST me when I say, YOU WANT THESE not that stupid little denso donut crap or those retarded kg shims that you have to press into the plates/mani. Both of those solutions are PURE crap and don't belong an engine. They are both band-aids and poor ones at that. This is a solution.
Old 05-18-2012, 09:33 AM   #25
RXTASY
idahorotary.com
RXTASY's Avatar
RXTASY is on a distinguished road
Hook me up J!
87 TII-E85-600+ RWHP and climbing
Life starts at 2 bar!
Come visit my forum! idahorotary.com
http://idahorotary.com/smf/index.php
RXTASY is offline   Reply With Quote
Old 05-22-2012, 04:51 PM   #26
fullfunctioneng
Triggers R Us
RE rails are available for manifolds either with or without vacuum tubes.
The with vacuum tube rails come with a spacer (which makes them a 60mm fitment)..
T2 rails are finished machining just waiting on ANO now!!
Click Here!
Click Here!
Old 06-23-2012, 11:14 AM   #27
fullfunctioneng
Triggers R Us
TII rails are NOW available!
Click Here!
Click Here!
Old 09-07-2012, 06:48 PM   #28
fullfunctioneng
Triggers R Us
Hey guys, just wanted to mention our new website/store is finally up! www.fullfunctioneng.com
Click Here!
Click Here!
