Old 11-14-2011, 05:46 AM   #16
Signal 2
Viable Fossil
Signal 2's Avatar
Originally Posted by yzf-r1 View Post
My biggest concern is draining the battery running the fans that long...
Just to confirm...running the wire lead to ground will cause the fans to run 10 minutes after the ignition is turned off but only if a threshold temperature is reached on the engine (can't recall now exactly what it is). So you don't have to worry about the fans running EVERY time you start your car.
As mentioned, if your battery is good there should be no problem and it does help a bit with underhood temps in the summer. Before moving to a PFC I used it for several years (through a switch so I could disable in cooler times) with no issues.
Jim
VR R1 FD
Old 06-03-2012, 02:36 PM   #17
mybadrx7
Mybadrx7
mybadrx7's Avatar
mybadrx7 is on a distinguished road
Im putting in new fans but theres two wires on the new bl and blue 4 on each old help i know black is ground and blue is hot on the new fans
mybadrx7 is offline   Reply With Quote
Old 06-03-2012, 02:37 PM   #18
mybadrx7
Mybadrx7
mybadrx7's Avatar
its a 93 fd
Old 06-14-2012, 08:06 PM   #19
88turboii
destroy, rebuild, repeat
88turboii's Avatar
on my 93, there was an extra harness inline with the relays that pretty much just shorted batt supply and ignition supply, so that fans would run with ignition turned off. if you remove this harness and plug straight into the relays, they wont turn on without the key turned
mybadrx7, BLK and BLU/ORG are ground, YEL/WHT and RED/YEL and WHT are 12V to fan
Old 08-24-2012, 09:23 PM   #20
Sm1nts2escape
Sm1nts2escape is on a distinguished road
http://www.fd3s.net/fan_mod.html
Sm1nts2escape is offline   Reply With Quote
