Old 05-23-2011, 08:08 AM   #16
Mazdatrix
Old 05-23-2011, 08:09 AM   #17
infernosg
IT'S ALIVE!
infernosg's Avatar
Originally Posted by tweiss3 View Post
MT?
I assume MazdaTrix.
I don't have my wiring diagram handy but is the neutral switch also connected to the ignition switch (i.e. can't start car w/o clutch depressed)?
Old 05-23-2011, 08:09 AM   #18
tweiss3
Mazda Lover
tweiss3's Avatar
Ugh, cali shipping FTL
Old 05-23-2011, 08:10 AM   #19
tweiss3
Mazda Lover
tweiss3's Avatar
I assume MazdaTrix.
The neutral switch isn't the same as the clutch switch, cause you can start the car in gear as long as the clutch is depressed. The neutral switch is in the transmission, and the clutch switch is under the dash i believe.
Old 05-23-2011, 08:28 AM   #20
You are correct. If the clutch switch fails, you cannot start the car. If the clutch switch is out of adjustment, you can't start the car. They're good to have though, even though mine is bypassed for the bump start and the remote start, but that's why I have the neutral safety switch. If the neutral safety switch fails, neither the remote start or the bump start will work.
Old 05-23-2011, 08:57 AM   #21
FRED
It's the interlock switch at the top of the clutch pedal thats in the start circuit. The lower clutch switch is for ECU information and cruise cut if installed.
Old 05-23-2011, 09:10 AM   #22
tweiss3
Mazda Lover
tweiss3's Avatar
Well here is the question. My car almost never idles, i let it idle for maybe 60 seconds before hitting the road, and my commutes are almost all highway. If i just put in the broken switch till next week when i get the new one, will that be ok? I won't have any detrimental effects, other than possibly worse mileage when i do stop at a light for 40 seconds?
Old 05-23-2011, 09:11 AM   #23
Or if you have an '86 you just don't have a clutch switch.
Old 05-23-2011, 09:35 AM   #24
Yes, but top of the clutch means the clutch must be on the floor for the circuit to close. If you put the clutch in, crank it and then lift the clutch slightly, the circuit opens and powewr to the starter is cut. Opposite holds true for the lower switch. Rest your foot on the clutch pedal with the cruise working and there is a chance it'll cut out.
Old 05-23-2011, 09:35 AM   #25
No, it'll be fine.
Old 05-23-2011, 09:38 AM   #26
tweiss3
Mazda Lover
tweiss3's Avatar
Sounds like a plan then
Old 05-23-2011, 10:02 AM   #27
You guys and your weird ass '86s
Old 05-23-2011, 10:15 AM   #28
tweiss3
Mazda Lover
tweiss3's Avatar
on a related note, its a hell of a lot harder putting the trans back in yourself than it is taking it out yourself
Old 05-24-2011, 08:28 AM   #29
tweiss3
Mazda Lover
tweiss3's Avatar
And done, she is much smoother now
Old 05-24-2011, 09:26 AM   #30
infernosg
IT'S ALIVE!
infernosg's Avatar
Ugh, realized this shortly after I posted. Is it Memorial Day yet?
Wow, with a lift and two other people it took me 4 hours to get a new transmission installed on my FC. The splines on the input shaft just didn't want to mesh with those in the clutch
