Old 03-01-2008, 11:49 AM   #16
McVicker
McVicker's Avatar
McVicker is on a distinguished road
so test the REW LIM/UIM and then swap it out for the RE LIM/UIM
Scrubs McBubs!
SakeBomb garage.com
McVicker is offline   Reply With Quote
Old 03-04-2008, 01:19 AM   #17
Bryan@BNR
Bryan@BNR is on a distinguished road
I would nominate phil as well! All these years we have been putting these cars together and phil never gets his car tuned! Come on phil, lets make 400!
Phil, if you want me to make it work on a FD lower manifold I can weld up holes that don't line up and drill and tap new holes, port match... Piece of cake.
Bryan@BNR is offline   Reply With Quote
Old 03-04-2008, 02:14 AM   #18
LOL!
Bryan, I'm hoping to make close to 400 or break 400 with this set up... I'll let you know if I need your help
Old 03-04-2008, 11:59 PM   #19
Bryan@BNR
Cosmo intake manifolds are nice and the plenums are larger than the REW. The REW runners are longer. Usually, larger plenums are better for top end and longer runners are better for TQ. Being forced induction with a standard side port or street port, it won't make a hill of beans difference between the 2 b/c power tends to fall off after 7600. If you were half BP or PP then you would need the added plenum area for increased RPM capabilities.
Bryan@BNR
Old 03-05-2008, 12:31 AM   #20
circuit theory
circuit theory's Avatar
circuit theory is on a distinguished road
I am totally lost with what or how we are supposed to measure using the sway bar brace???
AND THEN YOU PULLED OUT A FREAKING MEASURING TAPE AFTER THAT???!!!!
We Rove Rotary
Wise One Summer Sale
http://www.rotarycarclub.com/rotary_...ead.php?t=2475
circuit theory is offline   Reply With Quote
Old 03-05-2008, 01:15 AM   #21
scotty305
Nice photos. The bend radius looks better on the RE manifold, and the runners on that RE manifold have a much larger diameter than the REW manifold. Is this because it has been modified, or were the runners larger to begin with?
Does anyone know which was designed first, the RE or the REW manifold?
-s-
Old 03-05-2008, 08:49 PM   #22
Barry Bordes
Barry Bordes's Avatar
The runners on the RE are taller than the REW's but the main difference is the pocket just before the port.
The REW is like a 90º fitting vs. the RE’s 45º angle.
If you look closely at the floor of of the runners you may be able to make it out.
Barry
Old 03-12-2008, 02:46 PM   #23
felix_is_alive
felix_is_alive is on a distinguished road
so basically your`e saying that the RE has better ports than the REW ?
felix_is_alive is offline   Reply With Quote
Old 03-12-2008, 04:58 PM   #24
Barry
Thanks for the Pic Barry!
PHIL
