Old 12-16-2010, 01:08 PM   #1
sen2two
KTEC
sen2two's Avatar
Oil injection hole... Put to good use?
I just finished up my jig for doing peripheral ports (or semi-PP, and the exhaust too). I made it so I can adjust the jig to do a few different degrees of entry for the P-Port. I have a junk housing i will test it out on first to check for any vibration. It's heavy duty and I doubt will have any problems.
Any way, I was looking at it and noticed I can easily modify it a bit more to drill/mill/tap ect. where the oil metering jets would normally be. I normally do not run the stock OMP anyway, and usually use a bolt to block these off.
I then got an idea to put it to some kind of use. Maybe this could be a spot for a 3rd spark plug like they did back in the day for racing. Or even an extra fuel injector. Maybe a spot to inject meth. Not for cooling obviously since it will not cool anything if injected there.
Ideas? worthwhile? or just leave it the hell alone?
what I have:
What I had:
