Old 03-28-2008, 05:45 AM   #1
Barry Bordes
Barry Bordes's Avatar
Zero Clearance Side Seals
I like to set up my side seals as tight a practical. There are different thoughts on this minimum spec.
I have seen recommendations from .002” -.004” for turbo applications.
On my last engine build-up I mistakenly switched two side seals causing a
.002” clearance. This resulted in scrapping the RE front plate because of a
.004” wear groove on it in the area of combustion (where heat/expansion is greatest).
I decided to try .000”! Found this in an early Mazda paper.
What do you think?
Barry
Barry Bordes is offline
