Old 11-05-2010, 12:47 PM   #1
FDwarrior
Defined Autoworks
FDwarrior is on a distinguished road
Defined Autoworks 523whp 35r!!
Ok, where to start? I went to the dyno two weeks ago to tune my car for an autocross. I had no number's in mind for making power, I just wanted a tune. Logan at Defined Autoworks built and tuned this car, here is what happened. We did many pulls with these numbers and checked the dyno, its a dynapak as well. We also only had 93 in the car it has been running 93 since. I had a dirty k&N on the car, the whole time (4in). I also had 2 year old plugs in the car from my work bench. No nos, no tricks just whats here.
Here is the car, a rotary powered s14 beast
peak power ( you can see the spike to 16 pounds then it holds 14 pounds to redline)
peak torque
We were stunned, I don't think there has been a 2 rotor with just a half bridge and regular old 35r make this power. I will provide more detailed specs further down. The 35r is just a dual bb precision, NOT a billet wheel.
Here are the engine specs
13b-rew block and irons
13b-re port runners
D.A circuit port on the primaries
D.A half bridge on secondaries
D.A turbo exhaust port
Fd 9.0:1 rotors, balanced and clearanced.
3mm Apex seals
solid corner seals
New FC rotor housings
Coolant jacket modifications
race rotor bearings
high pressure oil reg
FC front cover
13b-re intake manifold
Turbo
1.00 divided turbine
p-trim wheel, standard wheel
.70 compressor housing
Electromotive Tec GT
Inductive coils
S4 Fc waterpump
Racing beat front pulley
Mazda comp waterpump pulley
Engine bay
Engine bay pics. The engine placement is excellent in the chassis. The front of the engine is even with the shock towers. The top of the block is about half way up on the towers. The intake is pretty tall so it looks like the engine sits high. The engine was initially designed to use a dry sump system, so the bottom of the block basically sits on the subframe. The subframe was modified and a custom oil pan was built by defined instead of using a dry sump. The placement of the engine did not have to move due to subframe modification. Everything was built by defined. The car was at Gordon's meet two years ago.
Im bad at taking pics, but you get the idea.
We are going to go back with race gas and play with the timing, the timing is conservative. I will update the thread with the new results.
FDwarrior is offline   Reply With Quote
