Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Garfinkle's Motor Works
Garfinkle's Motor Works garfinklemw@gmail.com (TN) Custom products for 3rd Gen RX-7's
Old 03-28-2011, 08:31 AM   #1
Originally Posted by Garfinkles Motor Works View Post
I will need to have a stock gasket to see if it is the same as FD.If it is not the same then I would need to write a new set of programes to cut the plate on the EDM .
I have a spare gasket for the turbo side that I can trace on paper and either scan into a .PDF to email you, or snail mail you the actual trace if you feel the scanned version won't be precise enough to work with. Unfortunately I don't have a spare gasket for the front cover side to work with. Hopefully someone on the forum could help out with that one, since I'm not going to have time to pull the pipe off the car to trace that side till next weekend.
Old 03-27-2011, 10:29 PM   #2
Rotorypolo
Rotorypolo's Avatar
Rotorypolo is on a distinguished road
wow....these are awesome for the twin turbo setup!!
1994 RX-7 PEP - (SOLD)
1993 RX-7 R1 - (under the knife)
1973 RX-3 13b 5 speed (DGRR 2011- 1st in class)
Rotorypolo is offline   Reply With Quote
Old 03-27-2011, 10:49 PM   #3
That is what they are for and some customers use one for the motor on a single turbo setup. A different one can be made for the non stock turbo . The fittings are the same both motor and turbo for the stock twins .
Old 03-28-2011, 10:35 PM   #4
Mail the trace to David Garfinkle
29 Wind Walker Ct
Manchester Tn. 37355
Use a sharp pin and remember the part will not be any better than the drawing because I can not trial fit before shipping . Trace the part three times to be sure .My parts usually fit very well .How many do you need ? I do not have a gasket for the motor ,wait untill you get yours or ask some one on the forun to help .If you need a little more working room in the area I think a size - 6 will be big enough .The ones for the third gen are a size 8 in the pictures . -8 is 1/2 inch -6 is 3/8 inch .The -8 is a tight fit .David
Old 11-15-2011, 09:07 AM   #5
I am making the fittings now with -6 fittings for ease of fitting.Some people found the -8 size a bit hard to fit .The smaller size will flow just as well ,remember the return oil is not under any pressure .
Old 12-05-2011, 08:25 AM   #6
If you're still making these, I'd like a set for my FC. I can mail you the stock return pipe to make your patterns. I'd like to stick with -8 though, as the stock pipe design is closer to a -12 ID, and a -8 will fit just fine on an FC.
To make a long story short, I recently did the RA oil metering pump adapter mod, which imposed a re-route of the stock oil return line. Picked up some cheapo flanges on ebay with -10AN male fittings that fit the turbo & front cover. Managed to plumb up a functional -10 return line using those, but the quality of these 1 piece machined AL flanges is terrible; they eventually get loose and leak.
Old 12-08-2011, 09:27 AM   #7
Send me the parts to copy and a discription of what you need .
29 Wind Walker Ct.
Manchester Tn .37355
include an phone number and shipping address .
Old 12-08-2011, 10:12 AM   #8
29 Wind Walker Ct.
Will get it on its way tomorrow. To ease shipping costs, I'll send you the smaller intermediate pipe that goes between the front cover and the turbo pipe. That should be fine for the purpose of making a pattern, as both flanges on that pipe are identical to those on the longer return pipe section.
Old 12-16-2011, 12:39 AM   #9
The programs are written and the test parts are cut .I will try to buy the -10 fittings Friday .
Old 12-30-2011, 10:07 PM   #10
Rx7aholic
Rx7aholic is on a distinguished road
Hey do u guys have a website? Because u seems make alot of nice stuff, I am myself need a few of these for and other stuff if u can tell us ur website that be great for order parts.
Khris
Rx7aholic is offline   Reply With Quote
Old 01-02-2012, 08:48 PM   #11
Just wanted to let everyone know these flanges are AWESOME! David made me a set of -10 flanges for my S5 T2, and these things are a work of art. Highly recommended, especially if you need to re-route the plumbing for any reason or if you R&R your turbo often. In my case, I needed to re-route the stock return pipe to clear around the OMP, after installing the Rotary Aviation OMP adapter.
Old 01-06-2012, 01:53 PM   #12
I am happy when you are happy, I try to take care of my customers .
Old 01-07-2012, 03:22 PM   #13
Monkman33
Still Building my FD
I am definitely going to need these for my bnr stage 3's twins.
Uh.... hi.
Old 01-09-2012, 12:40 PM   #14
I did not know that I had an ignore list and anyone was on it .I do not have a problem with yzf r1
Old 06-08-2012, 03:29 PM   #15
Monkman33
Are you still making these? I would like a set for us with my BNR Stage 3 twins.
Uh.... hi.
