Old 08-08-2010, 02:21 AM   #16
Oh OK, gotcha.
Yeah so far the bolt has been holding up, but I'm not sure it's had enough abuse yet to say it's really been tested. I'm still kinda iffy on the handle being used to shut the door haha.
Good luck with this next round of fixing, hopefully you won't have to repeat it. I get very annoyed having to do things over and over haha.
Old 10-30-2010, 09:07 PM   #17
adrock
adrock is on a distinguished road
I'm about to do a similar fix on my busted passenger handle, but I'm curious if anybody thinks JB Weld or epoxy putty like this stuff would do just as good? I've got a LOT of busted plastic to repair.
Thanks.
My sex machines:
-'94 Rx7 R2, Pettit TKT: SOLD
-'85 Rx7 GSL-SE: SOLD
-'90 Rx7 GTU, stock: SOLD
-'93 Rx7 base: my current baby
adrock is offline   Reply With Quote
Old 11-04-2010, 08:23 PM   #18
Everything I've ever used JB Weld on I've never had a problem with again. I love the stuff.
Old 02-14-2011, 12:52 AM   #19
Sideo
Sideo is on a distinguished road
great thread, this is the reason i joined rcc
Sideo is offline   Reply With Quote
Old 02-26-2011, 11:24 PM   #20
the spyder
the spyder is on a distinguished road
Most of the broken passenger door handles I repair end up being reinforced with 1/4" steel rod, welded to the top and bottom mounting points on the chassis (where it screws in from the factory). The handle is then centered and filled with a high strength epoxy and allowed to cure for 48 hours. Never had one come back in 4 years.
the spyder is offline   Reply With Quote
Old 03-02-2011, 10:58 PM   #21
prrex4ever
prrex4ever's Avatar
Great write up, thanks. I know that this will come in handy sooner or later lol.
Old 01-02-2013, 10:41 PM   #22
bbade
bbade's Avatar
bbade is on a distinguished road
Originally Posted by bbade View Post
This third fix will work as I am done playing around . I have ordered ABS rod from McMaster Carr and am going to make one heck of a robust stud. I will outline the process and post it here sometime next week.
My apologies for never finishing the write up. I logged in today for the first time in months (years?). The FD is currently sitting on jack stands in the garage awaiting a new coat of paint in the engine bay. Anyway, back to the write-up. I don't have detailed instructions as it has been quite some time since I finished this project; however, here goes.
The ABS rod worked out very well. Using a lathe I machined the rod down to the diameter of the original stud or just a bit thicker. I left a nice base at the bottom for ease of bonding.
Make sure you cleanup the bonding area (you can see the nylon attempt mentioned earlier).
Put some Plast-Aid under the post, then reinstall the plastic piece in the door panel to line everything up. After this initial bond sets up reinforce with additional Plast-Aid.
In summary I am more than happy with the result. Hope this helps, happy new year!
Proud owner of a base 1993 Montego Blue FD.
PFC, RB single tip, Koyo Radiator, KDR rebuilt motor, polished OEM front strut bar, FEED replica sideskirts, OEM 99 spec rear spoiler, SuperPro Bushings
Many thanks to Dave at KDR for sparking my rotor addiction.
bbade is offline   Reply With Quote
door handle, door panel, platic repair, window regulator
