View Poll Results: Which ignition setup would you go for?
LSx Coils with bulkhead fittings through the firewall 0 0%
Coil on plug 0 0%
other (please explain) 4 100.00%
Voters: 4. You may not vote on this poll
Old 08-03-2010, 11:25 AM   #16
jtbshaw
ORD - Old Rotary Dude
jtbshaw's Avatar
In this current build that I am doing for my son's TII, I am bypassing the J109s and getting the signal direct from the wiring. This signal will be then fed into the DR100 ignitors (2 leading and 1 trailing) then dispersed accordingly. Direct fire on the leading and back to the distributor for the trailing. It has been an odd experience to be working on a distributor based igntion in an FC.
