Old 03-01-2011, 02:36 PM   #1
Rotary Evolution
rotaryevolution.net
Rotary Evolution's Avatar
i'm not sure about the verts but the best bang for the buck to reduce wheel hop in the coupes is a pinion snubber, which costs about $7 and takes about 45 minutes to install, most of that spent removing the bins to get a drill into the center tunnel area above the nose of the differential.
this also helps keep your $180 differential mount from ripping under the stress of wheel hop.
Old 03-04-2011, 09:59 PM   #2
rotarydream
GT4202 REW FC
rotarydream is on a distinguished road
The 91 convertibles came with a 4.10. Info direct from the 1991 sales brochure.
rotarydream is offline   Reply With Quote
Old 05-13-2011, 05:33 AM   #3
project86
Can't.Make.Up.My.Mind.
project86's Avatar
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 01-01-2012, 07:46 PM   #4
I found that reducing the negative camber on the rear wheels reduces tire spinning on launch dramatically and seems to improve wheel hop. Launch acceleration measurements:
Stock suspension height: 0.93 gs max
Lowered 0.9" (Eibach springs, -1.8deg and -2.7deg): 0.87 gs max
Lowered 0.9" Camber corrected to -0.9deg and -1.6 deg: 0.93 gs max
This is using the stock size tires on a similar day (obviously not the same day).
I can still get axle hop, but it is only if a drop the clutch abruptly with the engine at 2000-4000 rpm and the throttle partially closed. Without camber correction, the axle hop was a problem on a hard launch, now it just squats and goes.
