| RX-7 3rd Gen Specific (1993-2002) RX-7 1993-2002 Discussion including performance modifications and Technical Support Sections. |
#1 | ||
Half bubble off plumb
Rep Power: 17 ![]() |
AWE......... YEAH!!!!!!success if mine... but I'm gonna have to redo the PFC idle relearn feature, it idles fine, then as it gets warmer, it idles higher and higher (up to around 2400 rpm) sorry you guys had to look at my face... it got caught up in the heat of the moment.. (oil pressure is not hooked up, thats why it shows no pressure :P) J.
"The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it." 360 gamertag: Tichlis |
#2 | ||
Too much time not adding more to thread...
too much talking on my part before... https://www.dropbox.com/sh/v6eq4ls2fn30v4h/YoVpCNVyGH that is link to all the photos as I update them... here are some Highlights... (done last summer) CAR RUNS!!!! (after some shenanigans with motor related stuff) put lots of kms on in short time bought some wicked in-expensive stock rims painted bronze from local member Bought Touring springs and H&R lowering springs (assembled) form same member for $100!!! again a great deal.... installed replica FEED side skirts and the Shine "rear skirts" replaced steering wheel de-powered my steering rack (properly) doing slow paced V-mount right now redoing the old interior plastics installed PLX wideband turbos not seq boosting correctly (yet) needs a tune after its all said and done And helped convert another piston lover to FD owner Skip to pics... OR... Long story (for those readers out there) Put 10,000kms (6,000miles) on this past summer in just over 2 months... other then my seq boosting problem... she runs great... Had to pull engine numerous times this summer... once to fix something (for get what... second, cause dropped something down intake and broke diffuser trying to get it out (The REW will eat diffusers... cause it did... ) put it back in, then while trying to rebuild some compression in the engine, a friend was not being careful when using one of my jimmy rigged tools, and ended up having a piece of metal go *INTO* engine, so... Third time it came out... Pulled rear iron, got foreign object out... re-rear ironed the motor.. installed. then started and ran like a Champ. Friend bought a FD that was in desperate need of some knowledgeable ownership... (the PO used a pry bar of some sort to "remove" various objects off the car.. the butterfly valve in the y pipe has a huge bend in it to match the chunk taken out.. (this is the car in the really Big garage) the car has blown turbos, so he bought a local low comp motor for $500 and is a great parts engine.. Things so far... To do, or have done. Getting rid of SMIC, In slow Progress of build a Greddy FMIC converted to V-mount. as pics note, its gonna be awesome... Using Koyo N flo (unless someone local wants to trade plus cash for a no name brand one :P) My goal is to have enough room between the IC rad to sneak in the filters for the Twins.. cause V mounts do a good job, but can do a Great job if the turbo gets fresh air.. Swapped out the ugly efini steering wheel for a later Mazda one, sold old wheel to friend, got a good deal on the new wheel... so that was my christmas present to myself properly de-powered my rack cause I was getting pissed off always having it off to the side when doing engine pulls. Now its gone, and very easy to pull motor... thats the same reason I got rid of my AC, got in the way too much Installed a PLX wide band, and matching gauge, into my real, little bit hacked up RE-A steering column gauge holder (thanks Supernaut) Im redoing all my plastics with Plasti-Dip... was in the states over the summer and picked up 8 spray cans... its over $19 a can here... and just over $6 per can down there... so I sold a few for $10 each. I'm excited to have an interior that will make the car look much more modren cause its not scratched to all hell. Also fixing the Gauge Hood, Jesus bandaid cause I want it to all look the same. so its been epoxied with fiberglass renforcement, and now sanding down to make it look as nice and pretty. (see pics) After the V-mount is done, and I have her running again, I'm going to dive into the engine and find out where I screwed up on my emissions removal/wiring harness redo/vacuum line redo. and fix that Damn things, so they spool perfectly... Also installed to Prosport Manual Boost controllers so I can eliminate the wiring/solenoids/vac lines, for those two and Simplify things a bit... Once its boosting properly, it going for a tune.. maybe to local tuner for a base tune.. then I'll post it up on the Datalogit group i'm in and see if the local guy knows his rotaries or not... then I'll get there help to Fine tune it. Then water/meth injection as per Mr Rice's recommendation... (would like to do preturbo on both twins... if possible while keeping the Airfilters) only person I've seen do it so far.. is from the 7 club (look at his engine bay pic) I want to keep the air filters on... http://www.rx7club.com/time-slips-dy...record-971246/ Pictures!!!! Link to them all.. https://www.dropbox.com/sh/v6eq4ls2fn30v4h/YoVpCNVyGH Thats the Link to all of them.. Here are some Honorable mentions with quick caption... ![]() at local Mazda Dealer, loving on the new ladies ![]() ![]() wide band install and brother business shop after hours... ![]() this reminded me of this... ![]() ![]() Put away for winter in tiny garage im renting (cousins garage) ![]() New wheel installed... look at album for old wheel pictures ![]() me getting serious business while wearing Wankel Mechanic shirt, after pulling a few things to start fabbing V-mount ![]() mostly sanded plastics... hood is not done due to needing to be fixed... hence the Band aids and Jesus Bandaid on them earlier... ![]() FMIC ----> V-Mount dreaming/early test fit mock up... ![]() My Uras Front Lip (probably going to plasti dip black...) cause I like to whore it out... local car imported with same lip.. I HAD the only one I knew of in North America... guess not any more... ![]() nice car though... ![]() Rims and Springs shocks I bought from Local 1.5 hour away, Member for $100 for each set!!!! There are a few other pictures in there as well... one last one... ![]() This is Lee ("Project D1" on 7 forum, with super wide and low CW 94) Thats all for now... Comments are welcome... I just dont want a shit fest... lol PS. feel free to give me shit for taking to long in the future.... J.
"The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it." 360 gamertag: Tichlis Last edited by Prodigy; 02-15-2013 at 01:40 AM. Reason: pics no work |
#3 |
Professional Stick Poker
Rep Power: 16 ![]() |
You've been a busy boy.
What level of boost are you running and are you experiencing any boost creep with the internal waste gate?
1988 N/A SE 2+2, dead stock and staying that way. ![]() 1979 SA22C stock? Not so much. http://rotarycarclub.com/rotary_foru...ad.php?t=15585 |
#4 | ||
With the 3" HKS catback, I hold steady @ 10.07 psi according to the adaptronic internal 4 bar.
I'm long to do 25-30 psi... Which is kinda retarded, considering how quick this thing is @ 10 psi... that EFR and that short mani are one hell of a combo... Once I get more tuning done I'll build a full 3.5" and have 12-14 psi as spring pressure, which I'll be fine with, then setup the boost by gear etc. To take advantage of that ecu logic controls. Looking to do 450-500 wheel ish. locally which would be a feat, >500 considering the altitude... I might need to get the DON Mega to help me get their... lol Then go stomp on some unsuspecting 'fast cars' in the aera... J.
#5 | ||
okay, lets start off with the Fun Bits...
1. New Fresh Air Intake for the Borg. 2. how she looks with the front lip fixed/installed 3. on the Dyno 4. Dyno sheet (this is with elliots tune, and W/M coming on with secondaries, hence the dip 5. 7 & MS6 DD, the MS6 took a semi up the ass on the hi-way in september
#6 | ||
1. SSI 4 setting up to log FP
2. AEM 150psi sensor installed 3. My Wallet became very light after buying these (do it once, do it right though) 4. Old H&R lowering vs $$$$ 5. The FD vs "average" sized trucks around these parts
#7 | ||
1. New blocking plate I made to clean up the look a little and enduce some hate
![]() 2. Fixed the broken handle after 6 years of ownership... Nothing 2 riv-nuts and some plumbing banding couldn't fix 3. 450lph wired up, Duestch connection for peace of mind 4. Start of the tear down to ABD delete and Paint the bay 5. Brake line nuts before 8 hours in the tumbler
#8 | ||
one of the Best and Worst tools Ive ever purchased... Best Cause its awesome!!!
Worst because Now I want to remove every bolt and make them look pretty 1. Starter bolt before a tumble 2. up 3. Starter bolt after tumble 4. up 5. All the shiny things!!!!
#9 |
Rep Power: 13 ![]() |
Looking good !
Turblown Engineering - Rotary Turbo Kits, Rotary Adaptronic ECUs and Rotary Performance Parts. TurboSource - Performance TurboChargers, Inconel Heat-Shields, and Adaptronic Distribution |
#10 |
Rep Power: 20 ![]() |
Glad you like the turbo. I'm gonna step up to that one I believe lol. You're doing great work, keep it up!
#11 |
Real world datalog showing boost curve with Jon's OE BW canister.. Looking forward to tuning the twin port turbosmart canister !
This large street port pump gas car is only 200rpms behind the E85 stockport shop car...
| Bookmarks |
| Tags |
| adaptronic, efr 8374 |
