Old 05-02-2017, 03:37 AM   #241
FC Zach
FC Zach's Avatar
Originally Posted by project86 View Post
So..... me and "Skinny Kyle" got the car running literally the day after DGRR. TPS and essentially a vacuum leak (tube running from the airbox bypassing the MAF and back into intake) were the culprit. Im gonna put my TPS back on and see what happens just to make sure.
This is awesome news but at the same time frustrating to know it was that simple. . Mostly because I swear I looked at that intake pipe more than once!
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 05-02-2017, 06:41 AM   #242
project86
Can't.Make.Up.My.Mind.
project86's Avatar
Yep. We all did. But thats ok. Im not really sure i would have wanted to drive it all the way there anyway. I forgot how uncomfortable it is right now.
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 05-02-2017, 08:01 AM   #243
Zach's DIN plate was mine, then I sold it to someone in Ohio(?), then Zach bought it from him. It has come back home!!
Lol
Old 05-03-2017, 11:57 AM   #244
project86
project86's Avatar
For now i'll probably mount it to the top of the steering column cover. The gauge comes in today.
'90 GTUs
'10 Toyota Prius
Old 05-03-2017, 03:29 PM   #245
careful with that area... the plastic is old and brittle and hard to find replacements (bc they break on removal)
Old 05-03-2017, 05:12 PM   #246
project86
project86's Avatar
Good point. Turns out it wont be able to go there anyway. I dont have a pod. Ill have to find a new place for it.
Got my new trans mounts and cross member installed today. Wiggled my drive shaft around too. Doesn't seem to have much play in it so I guess that means im ok on that front?
'90 GTUs
'10 Toyota Prius
Old 05-03-2017, 05:45 PM   #247
FC Zach
FC Zach's Avatar
Yeah, stay away from the steering column. They're as brittle as a lays potato chip.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 05-03-2017, 07:00 PM   #248
project86
project86's Avatar
Just remembered i found a big, ass spider living in my trans tunnel..... gotta burn the car.
'90 GTUs
'10 Toyota Prius
Old 05-04-2017, 01:30 PM   #249
project86
project86's Avatar
I've made a discovery...
I have the car on stands right now so I could do the trans crossmember and mounts.
I decided i'd start it up while it was off the ground and see if I could feel the vibrations I was talking about while the car wasn't in motion. Turns out I can. So that rules out the drive shaft for sure.
Any ideas what it could be?
'90 GTUs
'10 Toyota Prius
Old 05-04-2017, 02:01 PM   #250
tires
Old 05-04-2017, 03:05 PM   #251
project86
project86's Avatar
tires
They are new and balanced. And its happening without the car moving. I had a short chat with Myles and he's thinking engine mounts.
'90 GTUs
'10 Toyota Prius
Old 05-04-2017, 03:12 PM   #252
almoststockfc
almoststockfc's Avatar
almoststockfc is on a distinguished road
Seems like it would have to be. Unless you have the wrong counterweight on. That would be bad.
-75 RE_W_PU -
-76 Hercules W2000 - DGRR 2012 3rd place Old School
-75 Hercules W2000 MSO - DGRR 2011 Peoples Choice - April 2011 Rotary of the Month
-Rotary snowmobile powered go kart - DGRR 2012 Peoples Choice - RIP
almoststockfc is offline   Reply With Quote
Old 05-04-2017, 03:43 PM   #253
project86
project86's Avatar
That would be bad...... lets hope thats not it.
'90 GTUs
'10 Toyota Prius
Old 05-04-2017, 04:13 PM   #254
Wrong counterweight isn't something you generally would feel. It just silently destroys all your bearings...
Old 05-04-2017, 11:48 PM   #255
FC Zach
FC Zach's Avatar
I second that! We all knew how I drove my car with my previous motor. . It was all fine till I blew a coolant seal and found this upon disassembly.
I had a S5 front weight in my motor, ran that way for ~5 years
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
