Old 08-22-2016, 09:04 PM   #1
project86
Can't.Make.Up.My.Mind.
project86's Avatar
Originally Posted by FC Zach View Post
Bad sensor? Like a TPS or AFM?
I suppose it could be either... its just seems unlikely to me since they didnt really get used or have any kind of damage when i pulled them off.
I have a LED tester I made years ago for what I believe is for testing the TPS, I can bring it to your house in exchange for pizza & beer
done. just need to figure out a good weekend. Maybe this sunday afternoon? whats your work schedule?
Oh, you can test the AFM with a DVOM, you will just need to know what the specs are, I imagine these numbers are in the service manual.
I don't know what a DVOM is ......
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 08-23-2016, 09:17 AM   #2
TPS would not cause it to stall out like that. AFM would though.... as would bad plugs.
Old 09-05-2016, 07:05 PM   #3
project86
project86's Avatar
guess ill go get MAF cleaner and plugs then!
'90 GTUs
'10 Toyota Prius
Old 09-06-2016, 09:35 AM   #4
MAF cleaner will do nothing for an AFM. AFM is just a door and the sensor measures resistance and figures how far open it is to calc airflow.
Oh wait.... S5 right?
Old 09-06-2016, 09:58 AM   #5
S5 is still an AFM; the guts of it still uses a variable resistor. Instead of a hinged flapper door like the S4's use to change the resistance with airflow, the S5's use a sliding cone to do the same thing. S4 & S5 AFMs are not interchangeable; different electrical resistance vs. airflow curves and connector pin outs.
Old 09-06-2016, 10:00 AM   #6
project86
project86's Avatar
Yes S5.
'90 GTUs
'10 Toyota Prius
Old 10-06-2016, 01:53 PM   #7
project86
project86's Avatar
So... I have the VDI open now. I thought that would help. Doesn't seem to have done anything for me. I just did a little looking around on the other forum and found out that the VDI doesn't have to be open all the time anyway.
The only other thing I found is that there is a vacuum nipple for the injectors that is supposed to help with atomization. I can't recall if I have that connected to a vac source or not though but im not sure that would cause my issues.
I'm truly at a loss now.
'90 GTUs
'10 Toyota Prius
Old 11-01-2016, 12:18 PM   #8
project86
project86's Avatar
Getting closer. Adjusted the throttle cable. That helped some. It will actually run a little with out my foot on it but still dies after a few seconds.
'90 GTUs
'10 Toyota Prius
Old 01-12-2017, 10:42 AM   #9
project86
project86's Avatar
Slow going but i replaced plugs and wires last night. Seemed to help a bit but still no dice. AFM next? Coils?
'90 GTUs
'10 Toyota Prius
Old 01-12-2017, 10:45 AM   #10
We have some coils we can swap in. Also, unhook the AFM from the airbox and have someone push the cone in a little when you start the car. If that makes a drastic difference, we might have found a winner. I think you can also unplug it altogether, and if it idles, but doesn't rev, it's also bad.
Old 01-12-2017, 10:56 AM   #11
Great suggestion, but he doesn't even need to go that far. Just remove the airbox lid, remove panel filter (assuming still all stock airbox & filter). Then he can reach in with a finger & move the AFM cone.
You don't want to move it all that much - if you push it too far in, the car should go pig rich & stall if it's idling.
An S5 won't run with the AFM unplugged; not sure if it will even start that way.
Old 01-12-2017, 11:23 AM   #12
If that is left open, it'll cause a vac leak which could be the problem
Not to be the bearer of bad news but after seeing those plugs, it's time for a compression test.
Old 01-12-2017, 11:19 AM   #13
project86
project86's Avatar
Yeah its all stock. Looks like ill need some extra hands..... if you know what I mean.
'90 GTUs
'10 Toyota Prius
Old 01-12-2017, 11:51 AM   #14
project86
project86's Avatar
If that is left open, it'll cause a vac leak which could be the problem.
its there isn't a hole in the manifold. I was trying to wire the actuator open and the retainer came off so the actuator isn't there anymore. I was told it needed to be in the open position.
So the plugs had to have been like that when I drove the car home. And it was running great before emissions removal... so I guess im not understanding why compression would be bad?
'90 GTUs
'10 Toyota Prius
Old 01-12-2017, 12:24 PM   #15
I wasn't referring to the VDI crap, I was referring to the airbleed for the injectors.
It looks to me like the electrode broke off. I would pull the plugs and do a quickie audible comp test
