#1 |
Rep Power: 16 ![]() |
But what if the 2 (or 3) pumps in the surge tank outflow the in tank pump? I know it would take a while for it to deplete especially with the fuel return going to the surge tank.
But what about in a scenario like the texas mile, not saying I want to do it, but could this potentially starve if you are flat out for a long period of time? |
#2 | |
Rep Power: 18 ![]() |
#3 | |||||
Rep Power: 10 ![]() |
You know my rec ![]() Quote:
EDIT... after finding the flow chart and extrapolating the curve with my calculating eye, it looks like ~ 450/lph
#4 | |
![]() Have you even looked at the model I sent you? |
#5 | |
Of course I have!
#6 | |
So drilling and tapping the secondary rail is easy enough, however the Flex Fuel sensor will already be in the return line so I will have that temp. I need to know the DeltaT so I will get one of those AN to AN adapters with 1/8th NPT in the middle. I'll install that at the engine before the primary rail. I have the extra 1/8th NPT sensor I was planning on using for the Diff already, I'll just borrow that. looking forward to test this out... I like data. |
#7 | |
Very cool. I'm waiting on Aaron and Jayson @ FFE to come out with their new rails before I dive into redoing the fuel system and adding the fuel temp. I'm not going to get the DeltaT just the temp in the rails.
I would also like to add a pressure sender before the filter, pulling a log will let me know when it's starting to clog up. Quote:
Diff temp you say? Intrigued I am.... I may have to borrow this idea and put a sender in my tranny Indeed... I'm putting a PS2000 in my vert... I have so many inputs that I need to move the to a CAN EGT setup and I might even look into the CAN I/O Expander
#8 |
Ok cool, didn't think about the pressurized vs. no pressure difference. I have the hyperion baffle installed, so if my car ever runs and it doesn't work all that well I may make the switch.
#9 |
Rep Power: 15 ![]() |
I know my trans and diff temps :-).
Unfortunately no track data yet just street cruising. Max trans temp was 175 degrees F on a 800 mile drive in 62 degree F ambient day. Diff was about 180 degrees F on the sme day. Those hardlines look sexy. Last edited by RENESISFD; 02-06-2014 at 09:15 AM. |
#10 |
#11 |
^ Ninja edit above
:'( very funny John |
#12 |
#13 |
#14 | |||||
I have not seen them! Why have you mentioned them! Now I'm going to have to go look at them... Damn it John! Quote:
About what I thought they would be. On the track I suspect they'll get much higher, probably into the 250+ range. But at what temp does tranny and diff fluid start to break down? I can see all edits.... that was rough... Tracvista surprised the hell out of me at Pocono though! I think al you guys will be on the track before me... it's just a time thing. Are you guys thinking about Limerock this year? They should be releasing the dates pretty soon.
#15 | ||
![]() I think I like the "Classic" look of the MXL2 better, but this would be pretty nice too. (also about $1000 more expensive )![]() Quote:
That little sensor is really expensive for what it is, I would have much rather used a GM temp sensor. |
| Bookmarks |
| Tags |
| ducting, ducts, fd3s, jhnrx7, track |
