Old 11-21-2011, 12:46 PM   #151
rgould
Rotary Non-conformist
rgould's Avatar
rgould is on a distinguished road
What's a typical rotary EGT? I'm thinking all the titanium alloys I'm familiar with would not stand up to rotary combustion chamber temperatures and gases for very long. Titanium is poor in high-temperature oxidation and corrosion. Almost all modern-day turbine components (at least in the industry I work) are nickel-based. Inconels, Hastelloy, Waspalloy and other materials I can't name.
That I would agree with that on a modern-day turbine components but you also have to remember that modern-day turbines are cooled only by extra air being forced through the insides of the blades so the actual metal temp on a modern-day turbine components is a lot higher than the actual metal temp of a rotor witch is cooled on each rotor face by an intake charge of air and fuel and the internal side of the rotor has engine oil cooling it there by making the rotor more like a piston than a turbine component ( the turbine components never see a cool down cycle once its up and running )
std egt for a race rotary are around 1600 to 2000 deg F
piston race engine 1400 to 1700 deg F pending on tune and application
there are coatings that can be aplyied to the rotor for high-temperature oxidation and corrosion if that would be a problem
rgould is offline   Reply With Quote
Old 11-21-2011, 01:56 PM   #152
infernosg
IT'S ALIVE!
infernosg's Avatar
No need to explain to me; I design turbine stators (we call 'em nozzles) for a living We actually use compressor bypass air to cool turbine components the "cooled" air is actually north of 1000F, typically.
That isn't as bad as I thought but still too high for Ti. From what I've seen 1000F is about the limit. In the turbine actual metal temperatures can get above 2000F, which is getting out of range for most traditional nickel-based alloys and then you've got to start getting into directionally solidified and single-crystal alloys with protective coatings...
I'm familiar with your typical TBC's and environmental coatings on turbine components but not in compressors. In the aviation world compressor blades typically are bare Ti or have some kind of anti-abrasion coating.
Sorry to get OT but this is a good discussion.
Old 11-21-2011, 02:01 PM   #153
I support the cheapness. It's cutting weight and costs less than a used rotor. Win/win.
Old 11-21-2011, 05:08 PM   #154
rgould
rgould's Avatar
[QUOTE]Default
Yes the rotary runs hotter than a pistion engine with its EGT temps But it is still a water and oil cooled engine witch still goverend bt some constancs
Was not trying to o fend by explaining the turbin cooling. You never realy know the person background but it also lets outher people know what we are talking about
I would say that the running temp of a rotor would be less than 500 deg F if it's that high. The Apex spring, side seai springs and corner butten springs would not be able to keep there strengh at temps higher than that. Another point would be that a rotor beinging hotter than that the oil on the inside would want to cristlize due to the heat. Also the rubber oil control seai would be more likely to fail as well.
An alum piston melts at around 1200 deg F yet a race engine see EGT of 1400 to 1700 deg F and the piston does not melt if tuned correct thanks to the water in the block and the oil in the sump keeping operating temp in a range of 180 to 230 deg F for both water and oil. The same is true of the rotary yes the EGT is higher and the parts are hotter but they still operate in a range of 180 to 230 deg F for both water and oil.
But it's good to have this discussion
Old 12-08-2011, 11:19 AM   #155
Tegheim
Tegheim is on a distinguished road
Everything goes according to plan, but everything has its time
Meanwhile, the graphic card goes hot in the computer.
Is updating my drawings on the chassis and so on. And when inspiration is short, so make it a nice rendering, so you will be happy again
Tegheim is offline   Reply With Quote
Old 12-08-2011, 02:27 PM   #156
Tegheim
Old 12-08-2011, 10:58 PM   #157
pdxhak
pdxhak is on a distinguished road
Amazing project! Good luck!!
pdxhak is offline   Reply With Quote
Old 12-09-2011, 01:13 PM   #158
Tegheim
Old 12-09-2011, 01:32 PM   #159
Raksj04
I have Ultra power in me.
Raksj04's Avatar
1-4-2-3? firing order?
Old 12-09-2011, 04:12 PM   #160
Tegheim
1-3-2-4, maybe I done it wrong in the movie? :P
Old 12-14-2011, 01:00 PM   #161
Tegheim
A good start on a looong weekend...
Old 12-15-2011, 10:23 PM   #162
prrex4ever
prrex4ever's Avatar
^ wow!
Old 12-16-2011, 09:23 AM   #163
Raksj04
Raksj04's Avatar
I wish I had at least half of the tools and the know how to run them.
Old 12-16-2011, 11:01 AM   #164
Tegheim
3.45min
9.55min
Old 12-16-2011, 11:09 AM   #165
zoom44
zoom44 is on a distinguished road
fantastic work you're doing Tegheim. thanks for the updates.
on the titanium front- if you were art 7stock you may have seen these
they are being made for a helicopter.....
zoom44 is offline   Reply With Quote
