Old 01-06-2011, 02:08 AM   #136
FC3S Murray
frustrated!
FC3S Murray's Avatar
Originally Posted by MaczPayne View Post
His car's a monster! I didn't get a chance to ride in it since I worked when he ran, but damn does that thing scoot! He was playing around with the prop valve so he was smokin' his tires a bit before dialing them in
Sweet! I hope to run my set-up close to his. My dyno numbers maybe surprise me
Same pig, new soul
Old 01-07-2011, 03:46 PM   #137
MaczPayne
Bah!
MaczPayne's Avatar
Some pictures of the rear caliper modification my friend did to fit his brakes (same as mine):
Here you go Brian!
Pics courtesy of frijolee
Remember that the grind marks must run cross-ways on the caliper to prevent the formation of stress concentrations. Corksport's RZ kit instructions will have you grind them the other way; and while I haven't heard of any failing - I don't think anyone wants to be the first to have the calipers split while they're driving
Hubcentric spacer, notice the slight machining to get the rotor to fit.
Rotor sits closer than factory, so this area will need to be shaved down.
More here: http://www.norotors.com/index.php/to....html#msg14225
Hope this helps, Brian!
Johnson
TA FC in the works!
Old 02-09-2011, 01:51 AM   #138
MaczPayne
Bah!
MaczPayne's Avatar
Nothing much to update:
Picked up a new oil cooler setup - FD + FC oil coolers - an old setup from a friend's racecar. I should also have my Sakebomb HID's in the coming weeks as well.
Started this year paying off loans and whatever I owe so I can purchase a home in 12 to 24 mo's. It's a bitch.
Also getting into desert racing, so money's found a new avenue of escape, lol.
Karate, Cars, Racing - what a drain!
Johnson
TA FC in the works!
Old 02-09-2011, 02:12 AM   #139
Prodigy
Half bubble off plumb
Prodigy's Avatar
I know what you mean about avenues of escape for funds... last year I put my FD rebuild on hold to jump out of an airplane, multiple times...
its fun... just hella expensive, even more so to start...
J.
360 gamertag: Tichlis
Old 04-13-2011, 09:24 PM   #140
MaczPayne
Bah!
MaczPayne's Avatar
Did the El Toro Pro Solo this past weekend, threw on some brand new AD07's, so I had to break them in using 2 runs These babies are nice, can't imagine what the AD08's feel like.
First lap, came through the last sweeper (which also included the finish) a little unsettled...
Didn't place too bad considering everyone else had hoosiers or some kind of race tire I had absolutely no chance against Andy McKee's FD lol. My times were consistent so that helped out a good bit
After that, I finally got around to installing my Bi-Xenon's
Going to Spring Valley in Pahrump, NV 5/14, haven't been out on the big track since the accident!
Johnson
TA FC in the works!
Old 04-13-2011, 09:35 PM   #141
Nice man... I'm jealous you have so many rotards to race with. I'm lucky if one or two show up for our events! I'm surrounded by vettes, STIs and miatas...
Old 04-14-2011, 05:48 PM   #142
MaczPayne
Bah!
MaczPayne's Avatar
There are only about 4-5 rotaries at the events, including a rotary powered sprite
Johnson
TA FC in the works!
Old 04-15-2011, 05:28 PM   #143
FC3S Murray
frustrated!
looking great man!! I am gonna start SCAA this year after the LS1 dyno. Any tips or advice before i get there?
Same pig, new soul
Old 04-15-2011, 11:37 PM   #144
josh18_2k
if you're talking about autox... seat time, and focusing on the fact that slower is faster.
learning to autox a v8 rx7 is HARD. took me a loong time to dial back the right pedal.
in short, smooth as possible on throttle, and avoid sliding. its fun, but not fast, and is detrimental to driving skillz
Old 04-17-2011, 12:19 AM   #145
MaczPayne
Bah!
MaczPayne's Avatar
Biggest advice I could give is learn! Don't be ashamed if you make mistakes or come out slower than you'd expect. As long as you're willing to learn (ego left at the door!) you'll improve quickly.
Yup. The more you stay planted, the better!
Johnson
TA FC in the works!
Old 05-02-2011, 03:08 PM   #146
MaczPayne
Bah!
MaczPayne's Avatar
New addition
Johnson
TA FC in the works!
Old 05-02-2011, 06:45 PM   #147
Prodigy
Prodigy's Avatar
Those are matched very well...
Looks good...
Had rubbing issues I assume...?
J.
Old 05-02-2011, 11:26 PM   #148
MaczPayne
Bah!
MaczPayne's Avatar
Rubbing issues under hard cornering, would be fine if all I did was drive the car normally, but what fun is there in that?
Johnson
TA FC in the works!
Old 05-03-2011, 01:35 PM   #149
josh18_2k
do those actually add any clearance? doesnt look like it.. but they do look cool
Old 05-03-2011, 07:27 PM   #150
MaczPayne
Bah!
MaczPayne's Avatar
20m, but not much, it's about as wide as my pull, but with more uptravel clearance
Johnson
TA FC in the works!
