Old 05-09-2015, 09:46 PM   #1
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
MG Midget Madness (i.e. It was either this or kill it with fire)
lowered by Kevin Frank, on Flickr
1975 MG Midget - 1500cc; 4 speed. 1640lbs. with the cast iron engine and trans.
For those of you that don't know what kind of an idiot I am, I will give a brief explanation. I bought the above green hair removal tool to get around with until I could get my 79 SA back up. It seemed to only need a few things and I could either do a swap on it later, or fix it and make a little bit of money by selling it.
No dice. Every time I fixed one thing something was broken/screwed up that had been hidden away by the previous owner(s), or broke in the process of fixing something else. After about a year of fighting with it non-stop, and putting far too much money in it, (2 engines, 2 transmissions, carb, manifold, ignition, switches, wiring fixes, radiator, lights, etc etc. ad nauseum). I have had enough with the weak kneed, poorly designed and built, crappy 55hp engine and glass transmission (and worse wiring). Time for something infinitely better.
I have put quite a bit of work into suspension/interior/exterior so not all the money dumped into it will be wasted.
I will be cleaning up the '87 S4 NA 13B and 5 speed that I have and transplant the whole shebang into it. Hopefully I'll be able to retain the fuel injection, but we'll see as I go along. In addition all the wiring will be stripped out of it and either tossed in the trash, or burned in a black Sabbath bonfire to help it on it's way to hell. I will be using the GSL-SE front cover and pan to utilize the front engine mounts. The trickiest part (other than wiring) is going to be building a header, as there isn't a lot of room.
More pictures to come as I get stuff done.
GySgtFrank is offline
