#1 |
Don Mega
Rep Power: 19 ![]() |
*Updated front page of this thread for people who may not know much about how I have been running COP's for a looooooong time, all proven
*Some stress analysis Designed to take over 50kg of load, with less than 0.5mm deflection at its furthest point ![]() In actual operation in the engine bay, pretended it was an off road stadium truck jumping lol!!! The engine bracket will deflect 0.02mm and has a safety factor of around 50! so its plenty strong ![]()
www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration Last edited by RICE RACING; 01-11-2015 at 08:39 AM. |
#2 |
Don Mega
A different view...............
www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration |
#3 |
IT'S ALIVE!
Rep Power: 17 ![]() |
At the very least, I'm in for a set of the COP adapters, RRCOP-IGN1A-A. Still debating if I can use the full ghetto vertical mount setup, RRCOP13BREW-IGN1A-VF, to my advantage.
#4 | ||
Half bubble off plumb
In for epic Ignition system...
If you don't mind me asking Peter, how much retail do these guys go for? Also, do you have any pictures of them? J.
"The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it." 360 gamertag: Tichlis |
#5 | |
Don Mega
Physically connector is on front (pictured attached) Not 'much' different to IGN-1A Work has started on that, though wont be as fast as last system development as I have 1 million things on the go at once! ![]()
#6 |
Rep Power: 20 ![]() |
It's not THAT much more expensive. I was thinking like $200 per coil or something.
#7 | |
Don Mega
#8 |
FC3S
Rep Power: 16 ![]() |
How much is one of these setups gonna cost me rice? I haven't posted in a while but I have a GTX4202r sitting in the shed now. Waiting to get some work before I blow to much more money working on the car lol
#9 | |
Don Mega
As I type this I have the last elements being sorted, so I think I can get back to the detail in a fair time frame.
#10 |
Don Mega
M&W (COI-006) drawn up, looks like will not go vertical without some thought (gotta flip shit around) will
it in there ![]() New headaches start!!!! ![]() 4.46mm back from the front rotor housing edge (not as good as the IGN-1A can use 4 holes to bolt down. Still needs odd mounts due to offset on flanges, cant have coils lined up as wiring harness plugs smash into spark plugs sadly. This is only way to fit it vertical, otherwise will work on horizontal version ![]() ![]() ![]() ![]() ![]() Coil needs to be spaced out to achieve a horizontal fit, kinda defeating the benefits of the female coil end...... ![]() Only way I know how to fix this is to trim back the connector interface on the coil, potting it and fitting an autosport connector or DT series (similar to my original COP on first page) more remote style quick disconnecting position. This would free up some room, but not make it true 'plug n play'. Leave it with you all to mull over, if it was my own set up, then I would molest the coils fuck off the connector and trim it right back and gain 15mm space, and run the remote connector interface horizontal will need lots of mods to make it work/fit. molested coil below, needs connector trimmed, holes drilled in it, 3 wires inserted and fixed, pot the other side of the connector end, heat shrink and another connector, up in the bay where you can get to it, as on the front is a c-u-n-t. ![]()
www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration Last edited by RICE RACING; 01-13-2015 at 05:18 AM. |
#11 |
Don Mega
The M&W coil ideally is a Vertical Mount only as is, and no need to modify the coil, depending on 'demand' for this I will put this project on a lower priority
and fit it in when I have time to develop new coil spacers, engine bracket mount will be the same as in the IGN-1A 'VM', and will have new boot and spring coupling or adaption.Simple, now just to do it! p.s. the coils will only use a single bolt (lower tab on trailing and upper tab on leading coil) and body of casing for location as it is more than ample fixing method.
www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration Last edited by RICE RACING; 01-13-2015 at 07:28 AM. Reason: concept |
#12 |
Don Mega
M&W coil bracket F (front)
Using same engine bracket as in IGN-1A system ! ![]() p.s. checked this physically on engine and coil mating plug clears the knock sensor *just* so all looks good, this system will interchange with the IGN-1A coil set up
#13 |
Don Mega
This is the completed M&W CDI coil bracket system.
Will still need to work on COP interface *easy* compared to this stuff, will just do a rubber spark plug boot with internal coil spring, as its so short and fully encased by the coil tower will need no noise attenuation either... ![]() ![]() ![]() ![]()
www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration Last edited by RICE RACING; 01-14-2015 at 01:04 AM. |
#14 |
Don Mega
mung it
www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration Last edited by RICE RACING; 01-23-2015 at 08:43 AM. |
#15 | |
Get off my lawn!!!
Rep Power: 15 ![]() |
Are those prices including shipping? For those who are having difficulty navigating Peters site, his email is: peter@riceracing.com.au
'94 Touring - Cursed '96 NA Miata '14 Mazda3 Hatch '14 Aprilia RSV4 R Last edited by Fendamonky; 01-14-2015 at 09:20 AM. |
| Bookmarks |
