Closed Thread
Old 08-23-2013, 02:48 PM   #1
JL1RX7
Get a some of the extra horsepowers from Glenn the maniac all of the horsepowers king. He might a some left over on his quest for all of them.
JL1RX7 is offline
Old 08-23-2013, 03:24 PM   #2
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Unfortunately Glenn's horsepowers are GM contaminated.
GySgtFrank is offline
Old 09-04-2013, 11:55 AM   #3
GySgtFrank
GySgtFrank's Avatar
Progress has been slow. The front suspension is being a real pain. Lots of measuring, fitting, tack into place, and recheck. Pull it all loose, cut it apart, re-measure, re-cut, re-weld, fit, tack, repeat. I do believe it's right this time. I hope anyway as this part is getting tedious.
I had to move the lower A arms in and down again as the tires were a little too far out when the suspension was cycled up and down. It looks like hell at the moment, nothing some grinding and paint can't fix though. I can't go much further until I get the upper A arms and mount them, so I'll be removing the shock towers until I have to go to work for 2-3 months doing the harvest thing. So no progress will be made until I'm done with that.
kmember by GySgtFrank, on Flickr
Old 09-04-2013, 04:44 PM   #4
DO IT!!!! DO IT NOAW PUSSY BEFORE IT GETS COLD!!!!!
Just got caught up in the thread Gunny..... kickass work so far.... We should chat @ DGRR in 2014.... I'll tell you my idea... but remember there are witnessesd should you attempt to kill me
TitaniumTT is offline
Old 09-04-2013, 05:41 PM   #5
GySgtFrank
GySgtFrank's Avatar
Can't, have to go to work in a week or two so I can earn enough money to make it to DGRR, well that and car parts.
These are what I'm considering for the upper A arms. The arm itself is detachable and comes in different lengths. The mounting points are slotted and use slugs to move the arm side to side for caster adjustment. The adjusters would be nice to fine tune camber adjustments with large adjustments, and camber rate changes, being made by changing out different length arms.
Then use an adjustable coil-over shock attached at the lower A arm.
Pitstop USA also carries splined, gun drilled, front swaybars in various lengths and diameters so I can fit it into my custom application, since neither the Mustang or FB bars will fit what I have done.
I actually moved the tires inboard about 3/4" further on each side with the intention of using through bolt spacers to mount my current high offset wheels. When I get different wheels I will be able to use something with the mounting surface closer to center of the tire. At least up front.
Needless to say, my inner fenders will have to be... ahem... modified.
Now why would I want to kill you? Hurt you severely if it involves LS's, but not kill you.
Old 09-04-2013, 07:44 PM   #6
It may involve LS's
But the route I plan to take to radically update the FailBoats lack luster suspension will be vastly different and should allow for 255+ tires at all corners....
Old 09-04-2013, 08:12 PM   #7
GySgtFrank
GySgtFrank's Avatar
It may involve LS's
Going widebody, 255s wouldn't be any problem. I might be able to get away with 255s up front, but plan to use 245s as they are shorter than any of the 255s I've seen. I have looked at IRS and may do that myself sometime, but for now I just want to get it up and going with the suspension/chassis mods and decent power. When I start breaking the rear I'll revisit that idea I suppose.
... and both strut towers removed. Plasma cutters are the shit.
strut tower removal by GySgtFrank, on Flickr
Old 09-09-2013, 12:09 AM   #8
GySgtFrank
GySgtFrank's Avatar
Got some measurements from AJ to verify that I had my wheels placed correctly, I did amazingly enough. So I started on clearancing for the tires. I'm going for enough clearance to run 255s if I decide to, better to set that up now than wish I had later.
Cut out most of the passenger side inner wheel well as they definitely hit pretty much everywhere. Also notching the frame rails for clearance. The tires fit without it, but being able to turn them to full lock would be a rather nice luxury.
front suspension by GySgtFrank, on Flickr
open front wheel well by GySgtFrank, on Flickr
I will be putting in a loop to mount the shocks to as well as the upper A arm mounts on a pedestal off the frame rails. The frame rails and loop will be triangulated back to the firewall to add stiffness and support. Need less to say lots of bracing and figuring still to go.
I also need 2 inches more clearance at the top of the wheel arches for suspension movement with the large diameter tires. Need to pull the fenders to modify the basic body structure for that.
I'm trying to get updates posted even though it's not really presentable yet, as I will be disappearing for 2 or 3 months pretty soon to go to work. I won't be able to do much else until we finish up with harvest.
Old 09-13-2013, 03:45 PM   #9
GySgtFrank
GySgtFrank's Avatar
Since we got rained out today, I finished up the passenger side wheel arch and test fitted the wheel and tire. I had to do a little more minor trimming to ensure that the wheel can turn through it's entire radius while under full compression and extension.
Wheel at full compression:
full jounce by GySgtFrank, on Flickr
You can actually see how I mounted my fancy dancey cold air intake. The stock box is modified and through bolted to the bottom of the structure in front of the tire. I remove the front nose panel to access it. It clears, so it looks like I don't have to redo that part at least.
Old 09-13-2013, 07:06 PM   #10
Mitchocalypse
Mitchocalypse's Avatar
that car is in insane condition given its age.
nice.
Mitchocalypse is offline
Old 09-13-2013, 07:25 PM   #11
GySgtFrank
GySgtFrank's Avatar
nice.
Thanks Mitch. It is just a base model that came with the 12A and 4 speed. The only option it had was A/C. The engine was blown and it was probably destined for the crusher, as so many other 1stgens are, if I hadn't bought it. It has some hail dents, but very little rust. The only rust through it had was where the front of the lower rear axle control arms mount to the body, the normal spot. This is no longer a concern.
Old 09-13-2013, 08:36 PM   #12
chibikougan
chibikougan's Avatar
Bitchin stang bro!
Haha I can't even keep air in my tires
chibikougan is offline
Old 09-13-2013, 08:41 PM   #13
GySgtFrank
GySgtFrank's Avatar
Bitchin stang bro!
Bite me! Biotch.
Well, mine haven't exactly been getting a lot of wear and tear on them lately either. It could be worse, we could own FDs where one set of tires is all you'll ever need.
Old 09-14-2013, 05:51 AM   #14
LOL, yeah you get a break on tires but you'll need a damned good set of jack stands that are rated for 24/7 usage!
Pete_89T2 is offline
Old 09-14-2013, 01:23 AM   #15
the spyder
the spyder is on a distinguished road
Awesome build thread- how are you keeping the front end trammed in during the build?
the spyder is offline
Closed Thread
