Old 02-10-2009, 03:14 PM   #1
The RX-2 / Capella / 616 / 618 Info Thread
Base specifications of the RX-2 / Capella / 616 / 618
The best way to look at this is from a year to year perspective. All of the engine related technical information is in regards to a rotary powered vehicle unless otherwise noted.
1970
General info here
Specifications
Wheelbase: 97 inches
Length: 163 inches
Width: 62.2 inches
Height: ???? inches
Ride Height: ???? inches
Track: Front ??? / Rear ????
Curb Weight: 2,315 lbs
???? Mpg
????? Gallon Gas Tank
*The engine was carbureted with a 4 barrel Hitachi, 12A four port engine with a 9.4:1 compression ratio. Rated at ??? HP @ 7000 and ??? ft/lbs @ 4000.
*There were two transmissions available; a four speed manual and ????????? .
Manual gearing was as follows?????????????:
1st: 3.380
2nd: 2.002
3rd: 1.390
4th: 1.000
1974
General info here
Specifications
Length: 163 inches
Width: 62.2 inches
Height: ???? inches
???? Mpg
1st: 3.380
2nd: 2.002
3rd: 1.390
4th: 1.00
Paint Codes
