Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Garfinkle's Motor Works
Garfinkle's Motor Works garfinklemw@gmail.com (TN) Custom products for 3rd Gen RX-7's
Old 04-29-2008, 12:04 AM   #1
Garfinkles Motor Works
FD Air pump Deletion Idler (Interest feeler)
- Remove your air pump and still have full belt contact with water pump
- Idler will have a CNC cut Aluminum pulley with a double row sealed bearing rated at 12000RPM
The brackets and the shaft are steel. The shaft can be adjusted forward and back for belt alignment with belt adjustment being the same as stock with the stock sized belt. Single turbo applications may use a smaller belt which will allow the idle to tuck closer to the motor.
Pricing will be based on interest.
