FWIW, my stock instrument cluster tach typically reads anywhere from 50~150 RPMs lower or higher than whatever RPMs my Rtek 2.x modified stock ECU reports out when I set it up to datalog & monitor real time via the palm device. This is on an S5 turbo.
Rep Power: 21 ![]() |
you could likely reuse the ABS sensor. It puts out a steady signal. just take it from one of the front hubs (that are equipped)
we used that for some rally computers
#3 | |
IT'S ALIVE!
Rep Power: 17 ![]() |
so I'd have to find all that. Is it possible to get the trigger wheel and/or sensor separately and mount them on a non-ABS hub?
probably easier to just replace the hub. GXLs with it are common enough.
#5 | |
IT'S ALIVE!
I did some research on the ABS sensors and it looks like they're variable reluctance (VR, magnetic pickup, passive, etc.) so it's simpler than a Hall effect setup but not as good. Now if only I can find out how many teeth the ring has. |
Rotary Masochist
I believe there is a shop that makes a Hall effect speedo drive that swaps in the TII trans. Forget the name. Search on the evil forum. It may work in the NA trans.
The FD and Miata trans senders use a VR sensor. If one swaps to the NA trans it would work with an A/D converter. There is nothing really better about a Hall sensor. VR sensors generally are preferred for something like wheelspeed where there is a high resolution target. Just need an A/D converter for your gauge and ECU that want to see a square-wave input.
_______________________________________________ One stop Haltech, AEM, Syvecs shopping. Installation and tuning. http://www.lms-efi.com Free support. Drop us an email. chris@lms-efi.com 502-515-7482 Facebook @LMS-EFI |
#7 | ||
Rep Power: 10 ![]() |
#8 | ||
IT'S ALIVE!
I forgot all about the A/D converter. The speedometer I have says it can use a signal from either a VR or Hall effect sensor as long as the signal is 3V peak-peak. I'm sure the VR input would be slightly irratic if not wired absolutely perfectly so the A/D converter is probably a good idea nonetheless. Quote:
#9 | |
IT'S ALIVE!
