Old 11-30-2010, 06:32 PM   #1
Update 11-30-10:
I've been messing with the car, and I noticed a problem when trying to adjust the TPS:
When in range, one of the LED's on the TPS sensor "tool" lights up, but the second one does not. Before I messed with the car, the TPS sensor tool lit up both LED's when you adjusted it too far.
When I unwrapped the harness to cut out the extra emission wiring, I accidentally cut out the TPS wiring...
Got another harness and soldered everything back in, and all connections seemed good, but now after I put the harness back together, only one LED lights up, and then goes out when you push the plunger in too far.
I'm assuming that I mucked up the wiring somehow, but the car starts, runs, and drives just fine below 3800rpm. Perhaps the full range of the TPS sensor circuit is messed up?
Old 08-24-2011, 10:28 AM   #2
So, ever since I tore apart my car to paint the engine bay last year, it never ran quite the same after reassembly. I messed around with it but it never got very far, always running into issues.
This summer, I got tired of trying to make it work on the factory ECU, and had Chris Ludwig install a Haltech Sprint-RE standalone ECU, thinking that this would solve all my problems. He did a great job, and my car picked up 30ft-lbs of torque from stock on a Mustang Dyno, however we ran into an issue with the factory S4 TPS. Since it's a short range sensor, it only reads about 30% throttle input. Any more, and the ECU thinks it's being given 100% throttle.
This wasn't an issue for full throttle tuning, but it did result in a lot of hesitation during part throttle cruising. The recomended fix was to install an S5 TPS and throttlebody and use the full range TPS that normally controls the OMP function.
I also managed to score a godspeed front mount kit for cheap for the same person I got the TPS from, so hopefully they get here soon.
Besides the engine woes, I also have been neglecting the rest of the car for some time. It really needs a paint job, so I've been saving up for that.
